Question about Konica Minolta Dimage Scan Multi PRO Film Scanner
Konica Minolta Dimage Scan Multi PRO - Model AF 5000
Problem:
For some time now I've only been able to scan 20-30 images and then scanner suddenly freezes. I switch off computer and reboot. Scanner works for a time but then after a few scans it freezes again. I removed driver from system and disconected scanner from computer. I downloaded new driver Ds115e.exe and re-setup without scanner being connected. I then connected scanner and it worked ... but only for a short time before it froze again. Sometimes after an hour the scanner suddenly fires up and starts to datum and then works for a short period. However, at the moment when I've turned the scanner on, I get a green light but no movement from scanner. Repeated downloading new driver, etc. but not working at all now. Do you have any idea what the problem could be?
Thanks
Don
4 Suggested Answers
SOURCE: Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
Posted on Jan 06, 2010
Feist Geist
  • 73 Answers
SOURCE: WILL BE GETTING NEW COMP W/ WINDOWS 7 (64 BIT) IS
Download the Windows 7 Upgrade Advisor from the Microsoft site and run it on your XP system. Plug your camera to your computer and run the program. It should tell you if there are drivers available and if it is compatible with W7.
Posted on Apr 17, 2010
  • 9 Answers
SOURCE: can the Minolta Dimage Scan Dual II AF-2820U be
Yes, it will work in both OS.
Posted on Mar 10, 2011
Using my Dimage Scan Dual 4 SW with Windows 7 gives me trouble. Have konica Minolta SW ver. 1.0.0 for windows XP. It works fine on the XP computer. But I have great difficulties loading the SW on
Have you right clicked on the .exe file of windows 7 executable for the Minolta scanner to select compatibility to switch it back to xp.Have you tried to use third party twain drivers for scan software such as silverfast or vuescan instead?
Jan 24, 2015 | Konica Minolta Dimage Scan Dual IV Film...
Konica Minolta Dimage scan dual film scanner will not connect to windows 7
It's possible there are no drivers running under W 7 for this remarkable unit and it's a shame .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise ... trashbin . Yes , life is hard .
Regards .
Dec 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Does Kainanderson's solution work with Win7 64bit
Of course it does. I'm using both a Minolta Dimage IV and Minolta Dimage Elite 5400 Mk 1 (firewire and usb). Here's my latest driver:
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
May 13, 2010 | Konica Minolta Dimage Scan Dual IV Film...
When I scan 35mm negatives, the pixel aspect ratio is incorrect: the resulting images are stretched out by twice their width without any change in height. I can fix this after importing the image into...
I have the same problem with mine; medium format scans are fine but 35mm scans are stretched. The same happens with both the Minolta software and with Vuescan. Has anyone manage to fix this?
Dec 26, 2009 | Konica Minolta Dimage Scan Multi PRO Film...
Error 4 ... Konica Minolta Dimage Scan Dual IV
Use VueScan. A free trial is available so you can test it before you commit to buying it. Available for Windows and Mac.
http://www.hamrick.com
Feb 09, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Mnolta Dimage multi pro
Hello, Verify with the manufacture of the scanner to see if you have the proper driver(s) for the scanner, also if its compatible with your OS version.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
Konica Minolta Dimage Scan Multi PRO Film Scanner Logo
542 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
