I have a brand new tv appx 6 months old now the tv volume goes up and down by itself also changes chsnnels and goes off and on by itself help
  • 8,617 Answers
I would contact the place where you purchased it and check into the possibility of returning it. f you don't have any success I would contact the manufacturer. Most retailers will honor a return on a defective set.
Posted on Jan 22, 2008
6ya staff
SOURCE:
How do I fix my viso 65 inch smart tv when the volume just turns itself up tv is only 6 months old
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Vizio Televison & Video
LG HDTV Volume bar disappeared from Display
try factory reset in main menu or press menu continuaslly until it no longer comes up then 7777 on remote
May 05, 2010 | LG 42LC2D 42 in. LCD HDTV
Volume goes all the way up by itself
1. The volume up button on the remote may be stuck down- try wiggling the button to get it out. If it isn't the remote if the local volume control is in fact two buttons perhaps that one is stuck in or damaged.
2. The dvd sounds like it needs a new laser unit- a worn laser unit may play up like this.
It might be time for a new one as replacement can be sometimes more than the cost of a new one nowdays!
Jan 17, 2010 | LG LFD7150 Shelf System
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
New samsung series 6 lcd tv brand new, but has a problem , the sound keeps lowering down to zero by itself for no reason, auto volume is off??
When watching football on my samsung le40a656 there is ghosting behind players. It is connected to a sky box via a scart lead, any idea's
Jul 01, 2008 | Samsung Televison & Video
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
