Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
Kenwood dishwasher kdw8st2a
My kewood kdw8st2a dishwasher won't drain & it says e4 with a star symbol. I don't have any instructions. Can you help please/
  • 3 more comments
  • dannyfuel Sep 27, 2008
    i have same problem with error 4 and have no idea what i can do. can anyone help?
  • Anonymous Oct 15, 2008
    we have the same problem... the manual doesn't tell either what to do, or how to clear the error code and restart? any ideas?
  • mairevic Nov 02, 2008
    have a problem on my dishwasher its a kenwood and the error code is '4' i looked in the manual but all it says is that there is water overfill but gives no solution please help people please
  • cureton1977 Feb 19, 2009
    we have the E4 problem iv drained it but it's still going on i'v had this unit since oct 2008 so it's very new is every one ells with this problem had there unit a few monthes as well ?????????????? please let me know via my email thanks a lot
  • impsmum May 09, 2009
    I have the same problem, machine is 2 years old, I emptied it out and tipped it forwards then pressed the programme button, ended up with water on the floor but bingo it works, dont know how long for! I would never buy as Kenwood again,
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Posted on Feb 16, 2009
E4 means = overfilled........possible cause = too much inlet water
the star is rinse aid empty
hope this helps you :)
Posted on Mar 15, 2008
Dishwasher manuals
Not from here, but if you contact Kenwood at their online site, you should be able to download one.
Aug 07, 2014 | Kenwood KDW8ST2A Dishwasher
Kenwood KDW8ST2A - Power on, do not start.
Hi, try to reset the dishwasher power fuse. Check your dishwasher manual to do this.
Feb 02, 2014 | Kenwood KDW8ST2A Dishwasher
Need instruction manual for kenwood dishwasher kdw8st2a
Go to and fill in the details of your machine in the table on the left and you should be able to download your manual.
Oct 07, 2010 | Dishwashers
Kenwood kdw8st2a dishwasher e3 fault
The readings appear ok to me. The circuit that controls the element and any fuse in that circuit have to be suspected now.
Jun 08, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
I have a kenwood dishwasher kdw8st2a i;m getting code e4 overfilled how do i fix this
Error 4 says in the manual it means 'overfilled'! pretty useless info really. What it actually means is water in base of unit, normally caused by leaking pipe, check pipe connection at the back of the upper tray When you push tray in it connects with a down pipe, quite common for these to break. If ok check for other water leaks.
Nov 02, 2008 | Dishwashers
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Instruction Manual
Try this link:
hope it works for you.
May 13, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Apr 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
1,674 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
