Question about Polaroid i639M Digital Camera
Polaroid i639 Lens won't open. Beeps three times when I turn it on. It was doing that, then I got it working for no apparent reason, now doing it again. It's not the batteries.
  • jcbeasley Jan 24, 2008
    I have the same problem. Any solutions out there?
  • davantrey88 Feb 17, 2008
    My lens wont contract. It is extended and stuck. When powered on, it beeps three times and powers off. I have no idea how to fix this.
Ok, i just had this problem 5 minutes ago because i dropped my camera. I know, very stupid of me! but i was able to fix it myself, and hopefully you can too.
the problem is your lense. The lense being stuck causes the camera to automatically power off. if you can tell where the lense is stuck (you can usually see because it is jammed and lower than the rest, it slants in that direction) you may be able to pull it back out without damaging the camera. i just did this and i was so relieved!
Posted on May 28, 2008
My son dropped it now it wont open turn it on it beeps three times and shuts off
Unfortunately, with Polaroid cameras, if you hear (3) beeps and it will not power on; this means INTERNAL FAILURE and it's unable to be repaired.
Oct 05, 2009 | Polaroid i733LP Digital Camera
Beeps three times and shuts off
The lens is jammed. It requires manually resetting. If you in the U.K I can help you out. email me at kiddo242@hotmail.com
Aug 09, 2009 | Polaroid i631 Digital Camera
My polaroid i733 turns on the beeps 3 times then turns off when the sd card is in. i have tried formatting the card and camera but it still is not working any help
Had the same problem with our i733 Pink Polaroid. Beeps three times and then shuts off. The reason for this is that the lens is stuck in the partially open position. Because our camera was long past warranty and we bought it for $40 second hand I took the brute force approach. I grabbed hold of the lens and wiggled it from side to side while trying to pull it out (forcefully but being as careful as I could not to damage it) and then there was a small "pop" and the lens came out all the way and the camera was good to go again. Hope this helps.
Jul 25, 2009 | Polaroid i733LP Digital Camera
My Polaroid camera i631 won't turn on!!
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens is little bent to the side. I want you to put press on it to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Apr 04, 2009 | Polaroid i631 Digital Camera
Camera issues:(
I had the same problem, stuck lens, 3 beeps and shutdown. You must get pissed off at the camera first. Then bite the lens, clenching it like pliars (you could probably use pliars too), turn the camera on and immediately start pilling on the lens in the outward direction. The tooth grip unstuck the lens and vot it worked. you can take this solution to the bank.
Aug 20, 2008 | Polaroid i735 Digital Camera
Polaroid i834 the camera beeps three times and turns off,then the lens got stuck out
There could be something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try helping the lens in as you turn it on, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Jul 28, 2008 | Cameras
Pink polaroid i631 camera
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens2_bing.gif is little bent to the side. I want you to put pressure on the cam to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Jun 14, 2008 | Polaroid i631 Digital Camera
My lens won't retract or open and beeps 3 times and shuts off
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
May 15, 2008 | Polaroid i531 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Polaroid i639M Digital Camera Logo
292 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
