-   The problem is the push-on connector on the upper door-latch switch; if the plastic around this WHITE connector is brown (burning), the connection is going bad.
Cut the three white wires back about 1 inch and strip; obtain a new push-on and solder the three white wires into it-- a crimp is NOT sufficient for three wires into this little connector (defective design). Also clean the two blades on the switch before reconnecting as the heat has likely left a burnt coating.
-   Guest
I accidentally pressed the REM key on my microwave oven. I could not turn it off.Hours later a time...
(More)
I accidentally pressed the REM key on my microwave oven. I could not turn it off.Hours later a time was reached and the beeper sounded and I was able to press REM to turn it off. The time was in the middle of the night. Surely there is a way to turn off REM without having the time elapse or you change your mind. I pressed a lot of keys to no avail. JE186OSH-001
I have a fairly new microwave Model MHE14XMQ-4 It heats items up, but the fan doesn't come on to...
(More)
I have a fairly new microwave Model MHE14XMQ-4 It heats items up, but the fan doesn't come on to cool the magnatron down. Actually, the fan does work on high, but not on low.
Thermador Microwave MBY stops after 34 seconds no matter what time is entered or the power setting. ...
(More)
Thermador Microwave MBY stops after 34 seconds no matter what time is entered or the power setting. Tried reset and turning power to the unit off and restarting. Unit is 7 yrs old and worked a couple of hours ago.
