Question about Pioneer TS-W301R Car Subwoofer
Pioneer i got 2 Pioneer car subs that wont bounce but they used to
  • 4 Answers
You probably have blown speakers or the wires are disconnected
Posted on Jan 22, 2008
6ya staff
SOURCE:
How to wirea pioneer a pioneer tsw121 sub from4 ohms to 1ohm
That sub have dual 4 ohm voice coils, so it can be wired for either 8 or 2 ohms. It CANT in any way be wired for 1 ohm. Here is a diagram to wire it for 2 ohms.
Dec 09, 2013 | Pioneer Car Audio & Video
The outputs on my Pioneer GM-5300T are intermittent and low
yes they are perfect whenever I turn up the bass it just trips on and off
Feb 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
I have 2 pioneer tsw33c 10 inch subs and a pioneer
get amp kit if u wat high performenc get most exspensive kit as for the sub u could bridge them as for the stereo and speaker just make sure the posi
Mar 15, 2010 | Car Audio & Video
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Mar 14, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Pioneer amp and sub problems
That's a 4-channel amp, not a 2-channel, which makes me wonder exactly how you have it hooked up to your sub. Is the LED light on the amp coming on? How many subs do you have hooked up to it, and how is it wired?
Mar 04, 2007 | Pioneer GM-6200F Car Audio Amplifier
Pioneer TS-W301R Car Subwoofer Logo
108 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
