Question about Electronics - Others
Verbatim 1GB flash drive data recovery
I've got a verbatim flash drive. I plugged it in to my laptop and the laptop got pushed up against the wall and bent the flash drive. I can't retrieve any data that I've saved on it. Is there a way to recover the data?
  • Anonymous Mar 28, 2008
    my verbatim flash drive with all its files comes up with a message "do you wish to fomat" now. Is there any way to recover files?
  • 171 Answers
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Posted on Jan 25, 2008
USB port is not recognized in any of my computers or in any port.
It seems that the issue is related with the flash drive itself, I have came across with such problems many times. I guess now it's time you should go and ask for a replacement.Most of the flash drives comes with 5 years warranty. You may want to call verbatim customer support for warranty. Contact details
Feb 07, 2014 | Verbatim ® Store `n` Go USB Flash Drive,...
Verbatim portable hard drive has stopped being recognized by my lap top
try pluging in HDD to another computer to see if problem is with HDD or with your laptop, if HDD works OK with another computer that laptop has an issue
Sep 24, 2013 | Verbatim Electronics - Others
I bent my flashdrive and now it won't read. I initially was able to wiggle it around and once it read, I could drag one file to the desk top. Now, I can't it to read at all. What shall I do?
I would check the pins in the end of the flash drive and see if any of them are bent back. If these metal pieces aren't in the right place then the flash drive won't be able to connect to your laptop. I would try bending them back into place with a small flat head screwdriver. If you don't want to fix it yourself then I suggest you either buy a new flash drive or take it to an electronics store for more help.
May 01, 2011 | Verbatim VER95327 USB Hard Drive
What plug can i substitute for a verbatim USB500 portable hard drive? I only need the wall plug.
I believe you also need a dc transformer that has a wall plug on one end and the plug for your USB hub on the other.
Mar 19, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
I plugged in my 32 GB Verbatim flash drive with the store n' go software. I than turned it off. When I turned the computer back on and plugged in the drive, no prompt appears to open the flash and it is...
No, windows is probably just not assigning a drive letter to the device.
check out this tutorial.
I come across this problem pretty often with pirated copies of Windows 7.
If the above doesn't work or if you get stuck just reply to this thread and I'll help :)
Jan 22, 2011 | Verbatim EACH Flash Drive, USB 2.0, 32GB,...
I have a verbatim flash usb, the type that slides in and out. Simple question... should it stay temporarily locked when slid out for when inserting into usb drive? If I slide mine out then push to insert...
This problem is not typical, as there is supposed to be two small plastic tabs that that slide into equally small indentations on the plastic that keep the drive out while in use. Normally the drive would slide out and lock, then, when you're done do push the drive back in. Appears to be defective or broken.
Nov 08, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Just purchased a verbatim plug & go 4gig. my machine picks it up bt i get a pop up box asking me to format. when i select the 'format' option it tells me that windows could not format the disk. what's...
What machine do you have? What version of Windows? The USB flash drive is already formatted. Contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Oct 08, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Hello, My USB device got bent. I carfully bent it back and it looks okay but my computer said it malfunctioned. Is there any way to get my info off of it?
Probably just broke the solder join on the USB plug. I have used a fine tipped soldering iron, and re-sweated the join again, and you will probably fix it.
Feb 15, 2010 | Verbatim VER95327 USB Hard Drive
When I plug my portable hard drive into my computer it flashes
i speak only a little english. my problem is the next : i can´t see the portable hard drive in my pc ( windows xp ) . i would like to know the answer to this problem. thank you
Nov 18, 2008 | Verbatim SmartDisk Firelite Portable USB...
Electronics - Others Logo
713 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
