Question about Denon S - SERIES PREMIUM HOME THEATER System
Unit is locked up
Well this is my 2nd unit, first unit locked up after first use, best buy gave me another one, the unit is 1 year old, used in a game room, very low use. After being used for tv and and ipod one day, the unit locked up, per the manuelm the factory reset will not work. Out of 1 year warranty, When turned on the on/stand by button slowly flashes blue, nothing on the screen. Any suggestions???
    Top Expert:
  • Denon Master
  • 41,919 Answers
Probable power supply failure
Posted on Aug 17, 2017
SOURCE: Denon S-301 video problems
Theis is a known problem by Denon, you need to get a "patch" by denon to fix the problem. If you hook up to the other video out sources there is no problem (but no HD either)
Posted on Oct 01, 2007
  • 979 Answers
SOURCE: Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Posted on Oct 25, 2007
SOURCE: Protector flashing red when off.
If the speaker wires are shorted, it may be in protection mode. Try turning it on with no speakers attached.
If you've already done that and still have the same problem, it's broken and you should return it.
Posted on Aug 06, 2008
  • 119 Answers
SOURCE: Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Posted on Feb 25, 2009
  • 137 Answers
SOURCE: unit turns on for about 5 seconds and turns off
you have shorted output transistors which is causing the unit to go into protect mode. You can try factory reset by turning off unit then holding down speaker a and b buttons then turning back on.
Posted on Apr 14, 2010
What is error code E000110-0105 for a Canon imageRunner C4080 copier?
Hello Sir,
This error is about yellow laser unit:
Your error code translate:
E000110 = Polygon Error
0 1 0 5
1st line: Always 0
2nd line: Station where the error occurred (1: Y, 2: M, 3: C, 4: K)
3rd line: Main unit status when the error occurred (0: Activating, 2: BD control 1, 3: BD control 2, 4: Changing the speed, 3: Operating steadily)
4th line: Polygon control status (0: Suspension, 1: FG rotation, 2: BD control 1, 3: BD control 2, 4: BD Control 3, 5: BD control 4, 6: Phase locked)
In most cases you need to replace laser unit, but first, you need to check all the connections between electronic board and laser unit.
Best Regards,
Mar 27, 2015 | Canon Office Equipment & Supplies
Unit will cool only for about 1 to 2 min. at start then stops cooling. The unit runs good and everything seems to work well. The unit is about 6 years old.
Hard to guess from the info given, but the best thing to tell you is pull the unit out of its case, assuming its a window unit, and garden hose and nozzle using a solid stream, keep the water off the rest of the unit, start at the top work across and work your way down. Clean it very good and if its dirty you should get back to working properly, Clean coils is the name of the game, they have to reject the heat.
Jul 06, 2011 | Maytag M7D18E2A Air Conditioner
My compaq cq40 does not boot but with power. the caps lock and scroll lock light 4 times then stop, then light again 4 times then stop and so on. what is the problem? The unit is about 1 1/2 years old, not...
Try re - seating the ram modules and see if that helps. If not try them one at a time as only one may be bad.
You can use this as a reference:
http://www.insidemylaptop.com/remove-replace-damaged-lcd-screen-hp-g50-g60-g70-notebook/
Hope it helps you.
Oct 23, 2010 | Computers & Internet
1 year old sony PSP - screen is black
the screen/baclight will need replacing, best contact sony with a unit of this age.
Nov 25, 2009 | Sony PlayStation Portable (PSP) Console
Cannon printer mp830
6A00 means the purge assembly is stuck, on the right where the printhead rests when turned off. impossible to clean without disassembly. Best to replace #qm2-3032-000, about $19.95
Jun 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Unit wont turn on
Hi
First check the power suply cord(the conductivity),the on/off switch,the brushes,the fan and the armature.The wires too.
best regards savumihai71
Jan 16, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Do I need to replace everything, if I buy a new garage door open.
My 15 year old system broke down due to a worn screw drive. While parts like this can be replaced, it takes a bit of guts to work inside the motor, and the circuit board. I chose to buy a new unit. New units come with all the parts ... so you don't really save much, Depending on how old the system is, the old accessories may or may not work. Even though my old 1/2 H.P. motor was a chain drive, when I bought a new screw drive the mounting parts on the ceiling and on the wall above the door were compatable. So while you get the new parts in the box, you can use the old parts if it saves you time. I was not able to save the electic eye components as the number of wire leads was slightly different in the new model. It took me and my son about 2 hours to get the old one down and the new on up. Hope that helps. (by the way, the new chain drive is quicker and quieter)
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Ps3 no power
PS3 unit has fuses that probably failed. I wouldn't void the warrenty to try and change them yourself but this would be the place to start if you take it in for repair.
Jun 09, 2008 | Sony Playstation 3 (PS3) Console
Unit is not locking onto signal
Check your antennae installation. Mine was frayed and I had to buy a replacement for the car.
Apr 17, 2007 | Kenwood Here2Everywhere SIRIUS Radio...
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
