Question about Motorola Mobility RAZR V3
Greetings from New Zealand
Hi, None of the keys work, but I can still receive incoming calls.
  • jbgsz Jan 23, 2008
    Is replacing the flex cable something I can do?
  • Randy Koss May 11, 2010
    I do not know how old the phone is but, it sounds like your keys aren't making contact. I know that the most phones will answer/end the call with opening and closing the phone. Either use your warranty from Motorola (they give you one year), take it back to your carrier and get a new one.
    Sergeant:
    Champion:
  • 241 Answers
Yes, you can recieve calls, becaus the problem is your keypad flex cable - you can send the phone for repair - the cost is around $25usd + shipping.
Check in your local area shops to see if they can fix for you - don't pay more than 40euros.
thanks
http://horizonwirelessonline.com
Posted on Jan 22, 2008
My Blackberry curve 8520 DOES NOT DISPLAY y caller id's on incoming calls. These contacts are on my phone and do display when I receive a message but not when I receive a call. What can I do to rectify...
hi jenny202 You need to go into the phone section hit the bb menu key and set the display to all . Also if yout using a gmail on the phonr iy will sunc your contacts to your gmail and not sidplay then on your phone. You will need to look at the the settings .
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Dec 06, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
How to block incomeing calls on a samsung mdl sgh
If your fone has a blacklist feature which can be found in:
Settings > Call > Blacklist..
1). Enter the international code or the plus sign..
e.g "+" or "00"-Australia,New Zealand.
2). Enter country code.
e.g "61X"-Australia, "64X"-New Zealand.
3). Enter mobile number.
Activate this feature and you should be fine.
Oct 18, 2009 | Cell Phones
I can call out on my phone but incoming calls are not getting through.
When calls come through , receive and reject signs come up , press green to receive then nothing???
Sep 16, 2009 | Motorola Mobility RAZR V3
Cannot receive video movement link on the WebCam from New Zealand and Canada. We receive it ok from the UK. We have a new web cam and they can see us moving okay but our picture is static. This is when we...
the problem is likely not to be caused by your connection if you receive and send the webcam ok from the UK, probably the people you are calling have too slow connection for a dual (incoming/outgoing) webcam data stream...or they are using simultaneously some application which drains bandwidth.
Retry with Skype only running on both sides(kill any other bandwidth consuming app/update.).
if it still doesn't work, the people you are calling need a faster connection.
Feb 10, 2009 | Computers & Internet
Krzr K1 keys
have the keyboard replaced and the layer around the side keys as well to correct this issue.
Apr 11, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
New razr v3
chane the flex cable or try and reflash the phone firmware.
Dec 06, 2007 | Motorola Mobility RAZR V3
Lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Oct 20, 2007 | Nokia 1100
Buttons don't work!
None of the buttons will work. Is there any kind of locking device that maybe we've done and not realize it? The lights come on but you can not answer or press any keys?
Jul 17, 2007 | Samsung SCH-A970 Cellular Phone
Motorola Mobility RAZR V3 Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
