GMC FURNACE MODEL GMPN060-3
HELLO MY NAME IS STEVE: MY PARENTS HAS THE ABOVE FURNACE AND IT WILL NOT RUN CONTINUOUSLY TO HEAT THEIR HOUSE ABOVE 70 DEGREES. IT ALWAYS SHUTS OFF PREMATURELY AND THEN STARTS BACK UP 5 -10 MINUTES LATER. EVEN IF THE THERMOSTAT IS JUMPERED OUT IT WON'T STAY RUNNING ...
I've got the same furnace. I had to replace the auxilary pump that moves the water to the floor drain. The pump plugs into an outlet on the furnace and even has a light switch to turn the power source on and off.
If your folks have the same set up, make sure the switch is in the ON position.
Posted on Jan 24, 2008
  • 1,420 Answers
Sounds like s safety or overheat switch is tripping. Clean or replace air filter, inspect the venting for restrictions and make sure all registers are open all the way and not blocked by furnatue. Also check the condensate to make sure it is draining. If it continues to not heat, call a technician.
Posted on Jan 23, 2008
6ya staff
SOURCE:
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Coleman evcon furnace
So the furnace will come on and heat sometimes ? Then other times it will click but not heat ?
Check for fault codes if it has them and make sure it is clean inside burner tubes and clean the flame sensor.
Oct 13, 2013 | Heating & Cooling
The furnace will light up and the fan will blow but the flames cut out before my house reaches temp. i have the thermostat set at 70 and the house will not get above 55. i have tried turning the propane...
First, for those of you who might not know, "What is a flame sensor?" A flame sensor is a safety device. When your furnace's main burners ignite (light Up) the flame sensor picks up the heat from the furnace's main burning and says, "YES," and sends a signal back to the main furnace control board saying that it is OK to let the main burner stay on. Or if the main burners do not ignite, the flame sensor does not pick up the heat and says, "NO" to the main control board, Shut That Gas Valve and Main Burners Down! Thank God we have safety controls like the flame sensor. Most of the time, after turning your furnace's power off, you may clean the flame sensors with light sand cloth, emery cloth or steel wool. Reinstall the flame sensor and you are back in business! Over the years flame sensors can build up a light coating of burned-in dust and dirt. This insulates the flame sensor so that it doesn't sense the heat of the flame well enough, so by cleaning it you have almost restored it to its new condition. Seldom, but sometimes they do go out completely.
Dec 08, 2010 | Coleman Heating & Cooling
Carrier furnace will not heat house. Turned circuit breaker off and on again and it will kick heat on but only heats to move temp up 2 degrees. LED light is continuously on. All the manual says is 24 vac...
Sounds like it will not stay on long enough.I would try cleaning the flame rod/sensor.A steel pin next to the pilot or near the last burner to the left.Has a wire attached to it polish it with fine grit sand paper.
Mar 24, 2010 | Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Humidifier that never shuts off.
I am having the same problem with mine and it has started freezing up for no reason. Did you get any answers
Nov 20, 2006 | GE AHG40LA Dehumidifier
Heating & Cooling Logo
494 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
