Question about RCA OPAL M4001 MP3 Player
Washing machine my 2 gb opal had gone through the washing machine on a full cycle. I had opened the back of it and dried it out with the blow dryer. It won't turn on, but it will turn on when plugged into the computer. is there any way to fix it?
  • raysuave25 Jan 22, 2008
    I already tried that
Same thing happened to me. You might have to replace it unfortunatly.
Posted on Feb 06, 2008
  • 4,402 Answers
Nope sorry, you can take it apart and dry it some more...
Posted on Jan 22, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Malber wd 1000 just stopped working (power light won't go on) After a full wash and dry cycle the towels were still damp (started yesterday afternoon) was set to go through another dry cycle and it may or...
on my wd1000 i removed back cover and on top left side there is a electric/electronic component,i noticed a slight burn mark where one of the connections were.I cleaned and crimped it tighter and it has been fine ever since!
Sep 16, 2010 | Malber WD1000 Front Load Washer/Dryer
Machine taking about 3 to 3 and a half hours to do full wash and dry cycle also not taking in all softner
the cold valve has gone on the most washing machines there are 2 or 3 valves
e.g 1 hot 1 cold
or 1 hot 2 cold
the cold vale does the conditioner and it also puts cold water into the machine when it dryes into the condenser unit this cools down the steam off the clothes back into water
Jun 27, 2009 | Washing Machines
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
When yr washer does not rinse, it could be that your outlet is clogged. Ensure that yr outlet filter is free from any kind of blockage. Check this, it is a small door in front of the machine bottom. Plug off the wall & clean out, expect some water to come out when you open it. If this is not the case check out your outlet pump. Try reading your manual throughly; it surely helps.
Sep 29, 2007 | Malber WD1000 Front Load Washer/Dryer
WD63 Drain during wash but not dry cycle
the chances are you water valve has gone the drying cycle requires water to convert steam back to water, or poss your condenser is blocked this cant be cleaned easily better to change I dont know how competent you are if you have a muti meter you could test the soleniod which should have a resistence of around 3800 ohms. the valve is a triple one and the one that serves the condenser is the one facing downwards, disconnect power,take back off, turn water suppy off,take the 2 leads off the bottom solaniod only ,put your meter on contacts make sure you have selected crrect range on meter ie:10mohms if 0000 solanid faulty.Change valve if reading says 3800 valve ok change condenser
Aug 01, 2006 | Hotpoint Aquarius WD63 Front Load...
RCA OPAL M4001 MP3 Player Logo
42 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
