Question about Toshiba Satellite Pro M15-S405 Notebook
Toshiba power problem
I have a sattelite pro m15. ac adapter went bad, replaced it , worked for a month, quit charging. repalced the ac adapter with another ( all where factory replacements) but no go. took it in and was told it was the plug in and no they wouldn't work on it. got the plug in out, it seems okay. when I have the adapter not plugged in the light is on the brick and reads around 15 volts. when I plu it into the computer voltage goes to 2.5 volts and no light ( or just a flicker) on the brick. any ideas?
thanks
  • 58 Answers
Hi there!
im sorry but if the ac adapter flickers when you plug it in to the computer, then you have to replace the system board.
Regards,
Karlox
Posted on Jan 26, 2008
How to remove the cmos battery on toshiba sattelite laptop M15-S405?
you will have to open the laptop up todo this,or if you are lucky it could be under a little plate on the bottom of the laptop..i dont think you are going to be lucky.
Jun 21, 2014 | Toshiba Satellite Pro M15-S405 Notebook
I started charging my toshiba satellite M15-S405 laptop with a universal charger, IGO ac power adapter,with a #702 head/tip, that i bought from wal-mart, and its been having a yellow blinking lite in front...
Disconnect the adaptor and remove the battery from your notebook. Then connect the power adaptor and see if it boots up. If it powers up OK now you may have a bad battery. If the notebook still will not power up, the adaptor may not be compatible or there may be a different hardware problem.
Sep 03, 2013 | Toshiba Satellite A75-S226 Notebook
How can you tell if ac adapter is bad
Most times when this is happening, it is the battery that makes the light do this. Ether your battery is (has) reached its end life or you have an after market battery that is not quite compatiable with you pc. If you are unable to get a charge on the battery, I would have the battery replaced. Be sure to use your pc seriel number to find the best replacement battery.
Good Luck
Dec 17, 2011 | Toshiba Satellite Pro M10-S405 Notebook
Confuse the function of the laptop adapter Toshiba satellite pro
The AC Adapter has to be used which is compatible with the particular model of the Notebook. You can refer the User Manual came with the Notebook to know the exact model number of the AC Adapter. To confirm whether the AC Adapter is working or not you can check the LED light of the AC Adapter, if the LED is glowing then it is working fine.
The function of the AC Adapter is to charge the Battery of the Notebook.
You can also use the Notebook by connecting the AC Adapter while it is charging or when it is fully charged.
Mar 27, 2011 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2010 | Toshiba Satellite A60 Notebook
When using ac adapter to my Tecra 8000 the power light is yellow
Try a new battery and if the new battery wont charge then its either going to be a bad ac adaptor or a bad motherboad. If the new battery charges then you'll know that the old battery went bad.
Mar 29, 2009 | Toshiba Tecra 8000 Notebook
Toshiba sattelite a200 won't turn on
This is a common problem for toshiba laptops, unfortunatly. Usually when this happens either your laptop charger is fried, or you will need to replace the actual laptop plug inside the laptop.
Oct 31, 2008 | Toshiba Satellite A105 Notebook
Toshiba satelitte adapter went bad ordered new one it wont work
If the old one works you have another power supply or wrong one.
Check the properties of your power supply.
Related to your issue you also may consider this:
1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Toshiba Computers & Internet
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Toshiba M15-S405 Battery Won't Charge
hello,by anoteher charger,you`r capacitor on charger is poor.best solution for you is to by a new charger,that is 100
Mar 03, 2008 | Dell Inspiron B130 Notebook
Toshiba Satellite Pro M15-S405 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
