FixYa.com
Tags:
JVC XV841  PC Notebook
JVC XV841 Hard Drive Upgrade (by 2 users)
posted by rtpoole on Jan 22, 2008
I am trying to upgrade the hard drive in the above model laptop but cannot get the case open to do so. Please would you help with the procedure?
Many thanks,
Richard
Comment by rtpoole, posted on Jan 28, 2008
I still need to be able to physically open the laptop case in order to install the new hard drive!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Bayji, posted on Mar 22, 2008
I have the same notebook computer and would like to change my harddrive also. I did not see your answer to the original question. Also, will a HITACHI 2.5" 200gb 0A50940 sata 7200rpm work in this notebook?
Best Solution
posted on Feb 08, 2008
Helpful (85)
ehnonymouse
Rank:Apprentice Apprentice
Rating: 85%, 3 votes
You can find the method on jvclaptop.com. I have a 160GB drive in mine now.
Comment by ehnonymouse, posted on Mar 24, 2008
SATA drives will not work in this laptop.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 07, 2008
Thanks for Trying (70)
XxXShadowXxX
Rating: 70%, 3 votes
if i am not mistaking this is a built in drive thats not changable but you can use a external hard drive from the usb or fire wire port , i will try and look into this more , but i am almost possitive it is a onboard attached HD Chipset.
Solution #3
posted on Jan 27, 2008
priyabrat
Rank:Wiz Wiz
Rating: 78%, 98 votes
The BIOS needs to be updated every few years when technology changes to accommodate the operation of new parts.
The update is normally obtained from the maker of the computer, or in the case of a non-brand computer, from the maker of the motherboard or sometimes the BIOS maker itself.
The BIOS contains all the technical information about key components of the computer like disk drives, keyboards and display settings. It also keeps track of the date and time.
In recent years some computers required BIOS updates to make them better operate with plug and play features built into Windows. BIOS updates were also required to accommodate larger hard drives.
The BIOS updates are generally downloadable from your motherboard's or computer's websites. You'll have to do some detective work to figure out what brand and model of motherboard is in the system that you have to update. If you bought your PC from a small shop, a manual for the motherboard is usually included with the system's documentation.
Once downloaded to your hard drive, run the update program and you may be prompted to create a floppy disk, which can then be used to update the BIOS.
However some newer programs will do a BIOS upodate without the need to create a floppy disk. You just the run the update and the BIOS is updated after a reboot.
Rating Locked! (?) rtpoole has rated this solution as Thanks for Trying
Solution #4
posted on May 15, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I own/created the site jvclaptop.com and the method, along with pictures, are all there - memory upgrades too.
Please feel free to take a look.
Regards
Ian Allen
Solution #5
posted on Feb 17, 2008
Not Rated (0)
catnip20
Rank:Guide Guide
Rating: 79%, 5 votes
Hey, I had to replace the drive in mine, It's not too hard. Remove all the screws from the bottom of the case. Snap out the keyboard there are little snaps at the top of the esc & delete key use a small flat balde screwdriver. Then use a credit card around the edges of the main body to help snap it apart. Remove the top half, remove the silver speaker cover. Take out all of the screws holding the motherboard down. Remove the motherboard, The hard drive is under it. A note the ribbon cables are very very sensitive be careful when messing with them you don't want to tear them it will ruin your day ;-)
Comment by catnip20, posted on Apr 04, 2008
PICTURES !
I took these photos for myself to show others how hard it is to change the hard drive in these things so I apologize for not having more detailed step by step pictures, But if you read my previous post & look at these pictures it's not too to figure out. Note the tape to hold down the screws so they won't go missing while I waited for my new hard drive from newegg.
Removing Keyboard & Speaker Cover
http://img384.imageshack.us/img384/5251/scanimage16zy6.jpg
Keyboard & Speaker Cover Removed
http://img337.imageshack.us/img337/3403/scanimage10rb0.jpg
Top Half Removed, Showing Motherboard
http://img394.imageshack.us/img394/8316/scanimage07ow6.jpg
Top Half
http://img337.imageshack.us/img337/699/scanimage08kr3.jpg
Top Half DVD-Rom & Bottom Half
http://img208.imageshack.us/img208/3953/scanimage06gz9.jpg
Finished, Back Together - Photo from when I sold it on eBay to get a better laptop
http://img87.imageshack.us/img87/3568/im007921dl0.jpg
Can you Help with these PC Laptops problems?
PC Laptops
PLEASE HELP ME
i ACCIDENTLY DELETED MY AUDIO... Answer This...
PC Laptops
access to fan on HP ze4900
I have acquired three (one... Answer This...
PC Laptops
Internet Connection
I have satellite internet... Answer This...
PC Laptops
Removal of CD/DVD drive
There is no activity with the... Answer This...
JVC XV841 (MP-XV841) PC Notebook
Case opening
I have to replace my defective... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
