Question about Maytag Atlantis MAV6451 Top Load Washer
Fills with water than nothing!
My maytag atlantis filled with water but it will not drain out. it does nothing else either. it doesn't even make a noise
  • blacklab1 Feb 29, 2008
    i have a maytag atlantis m#mav8551aww,my problem is my washer fills when not in operation,when i open the faucets cold water run inside drum?why is this.what action should i take?please e-mail @palitosdavid@yahoo.com
  • robert samples May 11, 2010
    does it wash does the timer advance or does it just fill and stop
  • 51 Answers
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Posted on Jan 23, 2008
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
My maytag atlantis mav6520aww just stopping working. It fills at the correct water level and then just stops nothing else, Help!!! Can't determine if the motor or the belt both looks fine.
The possible problem here is the plastic gearing that connects the transmission to the motor to start the agitation has broken and will need to be replaced. If you forward the machine and it drains and fills properly then that will be you problem. This peice connects the motor as I said above to the transmission to start the cycle. This part sits between the motor and the tub itself and is a monster to replace yourself however, it shouldnt cost an arm and leg to have an appliance tech replace it.
Hope this helped
Dave
Feb 19, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Our washing machine fills up with water but does nothing else. I've turned it to spin to see if it would at least spin the water out but it does nothing. The cycle does not continue to move either. Does...
If you haven't used it in a while, The belt may be stuck in place. You will need to lay the machine on the side and turn the pulley with a tool. spray it with some sort of lubricant to help loosen it up.
Thats what happened to mine and it fixed it.
Sep 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Water fills but does not agitate or spin
THIS UNIT HAS A DOOR SAFETY SWITCH WICH ALLOWS WATER TO COME IN BUT NOTHING ELSE TO HAPPEN IF THE DOOR IS OPEN I WOULD START BY CHECKING THIS SWITCH.
Nov 29, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
191 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
