Question about Dryers
Hotpoint reverse spindryer keeps stopping
My machine will just stop for no reason. There is no noise and the timer doesn't turn. I've tried giving the drum a push. If I switch it off and on again it will sometimes start again or if I slam the door. Could it be overheating - it is de-fluffed though. Help me please. I can't stand not knowing how to fix it.
  • Moony1 Jan 22, 2008
    Thanks, I will try that. Have a good evening.
    President:
  • 1,314 Answers
Ok moony sounds like the motor is overheating and tripping out on its motor protector also called a thermal overload if nothing is restricting the turning of your drum then you can take the drier appart and clean the lint buildup out of the motor and sometimes this will fix it you can take a vacume and reversr the flow and blow it out about every three years you should do maintaince on your drier any way if that dont fix it replace the motor nothing last forever
Posted on Jan 22, 2008
  • robert samples Jan 22, 2008
    If that works don't forget to rate me. If not don't rate me and reply back and I will be glad, and help you further.
Gsh25jsxss
defrost timer is bad.
Dec 23, 2017 | Refrigerators
Ironman 530e elliptical
Try a different category for your question. Not likely to get help in the sewing machine community.
Mar 23, 2017 | Sewing Machines
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
My reverse action isnt working on my hotpoint dryer
Dear Sir:
See the different diagram for to see what is stop the dryer. God bless you
5_24_2012_10_42_10_am.gif5_24_2012_10_42_39_am.gif5_24_2012_10_42_53_am.gif5_24_2012_10_43_30_am.gif
May 23, 2012 | Dryers
When I turn on my Canon ir 1018 it doesn't stop heating. i.e it doesn't get ready for photocopying. It keeps on turning but doesn't stop in order to get ready.
This sounds like a faulty fuser assy. Basically the machine is warming up but nevers gets to temperature. The lamp has probably blown and for some reason it is not giving any error.
I would put a new fuser in and all should be well.
Jul 19, 2011 | Canon IR1018J Black and White Copier
While running the machine would bind and stop. Turning it manually it works fine for a while and then it will bind and the manual wheel will turn with some drag, but nothing inside moves. If you reverse...
OPEN THE THE GRIPPER WHICH YOU SAID IS CRACKED BY REMOVING THE SCREWS HOLDING IT AND TRY RUNNING THE MACHINE.ALSO CHECK THE SMALL WHEEL LOCATED IN THE CENTER OF THE WHEEL, THIS HAS TO BE TIGHTENED BY TURNING IN THE REVERSE DIRECTION.
REGARDS.
Jul 02, 2011 | Montgomery Ward Sewing Machines
Hotpoint WD61 stops near start of wash cycle
all in the timer. but there may be nothing wrong. sometimes in the cycle there will be a gap between water full and agitate or between drain and spin depending on settings. try it again and let it go and if there is a gap of more than 5 minutes than it needs a timer. most machines timers are right around $75 and you can most likely replace it yourself. sears appliance parts is the place to buy it. you can order it and they will deliver it to your door. or if you can get the phone # most of the outlets have a parts dept. also they take parts back for full credit for any reason.
Mar 05, 2008 | Hotpoint WD62 Front Load Washer / Dryer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Dryers Logo
53 people viewed this question
Top Dryers Experts
