Question about NAD 533 Turntable
Nad turntable when I switch the turntable on it some times revolves in the opposite direction. I switch off and on again then it goes in the correct direction. Also, how often should the rubber band be changed?
    President:
  • 4,402 Answers
The belt (aka rubber band) should be changed when it starts to slip
it is not whats causing the table to turn backwards. it's the motor or circut that drives the motor.
Posted on Jan 22, 2008
How do I set-up my NAD 533 turntable for initial use???
This Turntable looks nice. The belt goes around the two spindles [one big one small. the speed is adjusted by choosing which part of the small spindle you put the belt on. The upper platter rests on the big spindle and doesn't seem to be secured to it.
The counterweight should simply screw onto the back of the arm.
Manual can be found here: http://akdatabase.org/AKview/albums/userpics/10007/NAD%20533%20Turntable%20Owner's%20Manual.pdf
Jul 02, 2014 | NAD 533 Turntable
How do I set-up my NAD 533 for it's first time use ???
nadelectronics.com/products/turntables/533-Turntable
www.manualslib.com > Brands > NAD Manuals > Turntable > 533
Jul 02, 2014 | Denon DP-29F Turntable
Where can i get a on/off switch for a NAD 5120 turntable?
You will have to match it up to something that's currently available, as NAD is long out of business. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 06, 2013 | NAD 533 Turntable
My left channel goes out on my 533, when I touch the RCA in the back, it comes back on for a few minutes then cuts out again???
You need to replace the RCA plug with a new one. If it is on a seperate cable replace the lot, if not cut it off. There are only two wires one earth and the channel, you can't go wrong.
Dec 04, 2010 | NAD 533 Turntable
Revolver 'Rebel' Turntable extended leads Rotel RA 50 Amp - hum
could try fitting a serpresser as like cars do
also try a farraday loop which means put a few loops in your lead
Sep 07, 2009 | Audio Players & Recorders
My very old NAD 5025 got a hum noise problem
Check the motor shaft. It could be bent making the pully wobble which makes the whole turntable vibrate which gets passed through the needle. I just found this out on mine. Easy way to test is to hold the platter while the needle is resting on the record. The speakers will hum/wobble at a low frequency. Lift the needle off the record and the sound stops? It's the motor...
Jan 23, 2009 | NAD 533 Turntable
Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
NAD 533 Turntable
Just do a search in Google for "NAD 533 Drive Belt"
- OPTiC
Turntable Technician
www.1200s.com
Sep 01, 2008 | NAD 533 Turntable
NAD T760
You should connect the RCA connectors from your turntable into the phono input of the preamp. Also, make sure you have the grounding wire from the TT connected to the grounding on the preamp (if you do not have a grounding point, then just connect it to one of the screws on the preamp). Then connect the output from the preamp to either the Tape or the CD points on the T760. On the front panel press tape monitor and you're done.
Check and let me know how it goes. My set up's working fine except for clarity, which still needs to be perfected. I'm using a normal step-up phono stage.
Regs/ Avinash
Mar 29, 2008 | NAD T760
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
NAD 533 Turntable Logo
283 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
