Question about Janome Memory Craft 9000 Computerized Sewing Machine
Machine screen lights up but shows nothing.
I have a Janome 5000. I turned the machine on and the face lights up but shows nothing. The needle will go up and down but will not sew. I have tried everything. Any Suggestions?
  • Janome Master
  • 1,388 Answers
Have you raised the feeddogs, or are they still down for free motion quilting ?
Is there a lot of lint under the needleplate holding the feeddogs down, .......remove the needleplate and give it all a good cleanout, there's also almost certainly accumulated lint around/beneath bobbin case, do this too, while you have the chance
If it is all still needing answers after this little housekeeping,
I can send you the diagnostics checks for the MC5000 as a pdf, though they are not readable (too small) if I post them as a reply here, so if you send a request via the "Contact Us" page
www.bargainbox.com.au I shall forward it.
BTW...When was your machine last serviced ?
Posted on Feb 17, 2008
Were can I order a sewing machine needle for my Craft Master 5000
Try these people
http://www.sewingpartsonline.com/assorted-needle-set-5pk-janome-200343004.aspx
Nov 24, 2015 | Craft Master Sewing Machines
Janome model 1550
Do have a manual for the machine?
Jan 26, 2014 | Sewing Machines
Janome 9700 suddenly is showing warning. Raise
Ask the seller! He has a vested interest in helping your machine work! As a former newspaper writer, believe me, if you send something to a local rag, about your problems with your Janome, the seller will sit up, and take Notice!
Oct 23, 2013 | Janome Memorycraft 9700 Computerized...
Janome 9000 bobbin thread ends up on top of fabric
change the needle--
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the top thread--top & bobbin
check the bobbin to make sure the bobbin is not damaged
reinsert the bobbin in the case correctly
Jun 03, 2012 | Janome Memory Craft 9000 Computerized...
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
The needle and thread get stuck at the bobbin and the lo light come on my 8077
Turn the power off and replace the needle with a new one, making sure the install is as described in the manual for your machine - on most newer models, this is with the flat side of the needle shank facing the back of the machine.
Before turning the power back on, raise the needle to it's highest position. Remove the face plate, bobbin and bobbin case. Clean the area in and around the shuttle from lint and/or threads that may be tangled there.
May 15, 2010 | Janome 8080 Computerized Sewing Machine
Newholme sewing machine model 361 which way ti fit new needle
Try: flat side of the needle shank facing the back of the machine or facing to the left. One should form a stitch.
May 15, 2010 | Janome L-344 Mechanical Sewing Machine
Janome 5000 screen remeins black
my needle keeps going up and down  after i stop a seam  is it my foot control? if i stomp  hard on foot control the needle stops as  it should
Jul 05, 2008 | Janome Sewing Machines
Janome 9000 willl not work when turned on
My Janome 9000 has always done that. I can prevent it by raising the needle when I first start the machine, getting it to sew quickly or raising the needle and letting the machine sit for a few minutes. I think my computer wants to warm up a minute. As you can see I.m not a technical person but it works for me.
Nov 16, 2006 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
103 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
