Question about HP OfficeJet k60 All-In-One InkJet Printer
Blurry print Hello: I'm experiencing blurry print from my OfficeJet K60 printer. This happened a few weeks ago and I ran the Clean Cartridge function from the Maintenance menu and that worked. Since last night, it's back! I ran the Clean Cartridge function again without any luck. Any suggestions? Thanks!! Jennifer
Hello Jennifer,
Clean the plastic ribbon with the thin black lines on it that runs from the left to the right of the printer near the cartridges. The thin black lines are used to keep track of the position of the cartridges.
If there is grease or anything else on the ribbon, the photocell mounted on the cartridge carrier can not keep track of the position and your prints will become blurred.
Posted on Dec 02, 2008
  • 4,402 Answers
Replace the cartridges
Posted on Jan 22, 2008
Over a few weeks colour printing on my ESP7 has detriorated in quality. A few days ago it started to print only in yellow. Then it aasked me to insert a new colour cartridge, which I did. It again asked me...
hello user
try to remove all the cartridge and turn off the printer unplug the power from source power. clean the cartridge, try to wipe it with cotton and little bit warm water.
i try this problem before have the same problem and same unit.
inform me what will happen ill guide you thru the process.
Nov 13, 2010 | Kodak ESP7 PP All-In-One Printer
I have installed new cartridges but the status panel keeps telling me to remove and check colour cartridge
Reboot your PC , unplug your power and usb / parallel port and see if this clears the message. Run a "clean cartridge and align paper" also
Did you buy refilled ink cartridges, 'cus if so, this could be the problem,
Sometimes it happens to me also, hwen I buy those refilled cartridges but I just ignore it and it prints, scans and copies, even if that error message is on the front screen.
Nov 14, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
I bought a new color print cartrige and since then my printer align cartridge keeps failing so I can't use my printer. I have reincerted them many times and ran the align cazrtride and I get the same thing...
Sorry to ask a dumb question but did you remove the protective tape on the cartridge when you installed it? If yes, then proceed to the following HP help page where the align cartridge error is outlined along with several solutions. Best of luck!
OfficeJet k60 Align Cartridge
Nov 06, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
How to change ink cartridge officejet k60
What you need to do is open the lid of the printer and the cartridge will roll to the middle and you'll see the ink cartridges and all you have to do is pull out the desired ink cartridge that you want to replace and put in the new one. If you have any other questions please let me know.
Apr 09, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error: Incorrect Color Cartridge Intalled
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
HP OfficeJet K60 Align cartridge problem
ok the link i put here for you is very long page of typing so for hp
i found you the link to go threw the alignment process
sorry i cant type the whole page for you but the link is here
May 18, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
HP OfficeJet k60 All-In-One InkJet Printer Logo
120 people viewed this question
Ben Johnson
