Television making chirping noise
Hi i have got a panasonic tv model no TX-28PL1
The problem is when i moved the telly from my moms to mine i plugged it in and it comes on standby mode so i press the on button on control on doing this it starts making a chirping noise.
I am confident in working on tellys and soldering new parts also i have two tellys i can take parts out of.
my problem is whats wrong and what do i replace and where is it located.
Please could you help me with this problem much apriciated many thanks in advance
  • 2 more comments
  • paul proctor Jan 22, 2008
    hi many thanks for quick reply where abouts on the board is this i have replaced resistors before but is it the thing with the red wire that goes to top of screen if so what end do i undo the red wire from
  • paul proctor Jan 25, 2008
    Ill give it a try and let you know but is their any air pressure when i remove the suction cup or is it just pushed in as i know their is several tonnes of pressure inside the screen does this affect this removing the suction cup or does the air remain under pressure whilst suction cup is removed please let me know as i dont want to damage the telly further.
    I am confident in soldering as i have worked on electronics but just not tvs so any help is much apreciated many thanks for your help
    you mean i pull it out of the tube on top of screen the cup seems stuck to screen is it glued or anything like that also is their a clip under the rubber as i know their is on some tellys also what part of the red lead do i earth out to make sure their is no power left in it.
    Also the telly has been off and unplugged for 48 hours or more will this dispel the power or will their still be power running through the lead thanks alot for all your help
  • paul proctor Jan 28, 2008
    more chirping noise from back than hissing sounds like staticy sound like telly trying to start but it wont comes on standby starts chirping when press on button on controll
  • 2,427 Answers
Pauldonp change your screen will you,, also look at your flyback transformer and ensure thats not hissing.. YOur screen is loosing compression
Posted on Jan 25, 2008
  • Rishi Roshan Ali Jan 25, 2008
    yes the cup is glued using high pressure high temperature resistant silicon.,. also known as gasket maker
  • 281 Answers
Chirping or hissing from the TV is caused by a faulty CRT base socket in 95% of the cases. Replacing the base socket is an easy job, but care must be taken to get the same replacement base socket. You better desolder the existing base and take it to the shop to get one with the similar connections. Good luck.
Posted on Jan 22, 2008
  • 1 more comment
  • Arun John
    Arun John Jan 25, 2008
    The redwire is the final anode, there is a clip lock at the end, you can use a screwdriver to push under the vacuum cup and then lift the connection. But before disconnecting it discharge the voltage by connecting a wire to the board's ground and shorting it to the end at the cup. Then clean both the cup and the socket on the crt with a clean cloth and replace it. The cup is rubber, so don't use petrol or such things that can harm rubber.
  • Arun John
    Don't worry about any air pressure, that is not an opening into the picture tube. Gently push the lock with a screw driver, you can even tilt it and pull out without a screw driver. This will no way damage the tv.
  • Arun John
    Even if it is off there are chances that some power to remain, just connect one end of the wire to the ground and other end into the cup. If the cup is already glued you will have to get a new cup, it may not be easy to get it off untampered. There is a clip under the cup, it is just like a spring that spreads its two ends siedewards. Try to get a new cup and then replace it, once you undo the cup from the tube you will get an idea as to how to change the cup. It is easy and intuitive.
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
We have a Panasonic TV - Model TH-37PX60U (purchased 08/2006) that makes a "chirping" type noise periodically - sort of comes and goes. Any idea what this might be? Thanks, Mike G Pinellas Park,...
Sometimes that "chirping" is caused by loose windings on various transformers. You can usually isolate a particular transformer by pressing on it when it is "chirping" & it may stop "chirping" or the frequency my change. If that is the cause, you can A: replace the coil, B: replace the Printed Circuit Board, or C: Do nothing as it really isn't hurting anything but your nerves.
Oct 22, 2011 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic tv tx-32pk with no power.
ic wil damaged...otherwise plz use another plug board....may be ur switch board complaint
May 07, 2009 | Panasonic TX-32PK1 TV
Tv chirpping
Check Horizontal Output Transistor...if shorted = replace it AND
the flyback transformer with Panasonic parts.If xistor is good,
replace flyback ONLY...............................T.
Jan 26, 2008 | Panasonic TX-28CK1 28" TV
Panasonic Tx-28PL1
Check Horizontal Output Transistor....if shorted,replace both
Horiz out transistor and flyback transformer...Use Panasonic
original parts, if possible.If transistor checks ok, then just replace flyback transformer ONLY.......................T.
Jan 25, 2008 | Panasonic TX-28CK1 28" TV
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
No picture or sound - TV makes chirping noise
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
728 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
