Question about HP LaserJet 3055 All-In-One Printer
No paper pickup
I have spent the day trying to fix this printer. I made one copy and it worked fine. When I tried to copy another page, it said there was a jam. I checked everywhere and there was nothing I could see. I removed the ink cartidge, turned it off and back on. Then the message changed to, "No paper pickup." Well it has paper in it. It just won't work. Can you help me?
  • chrisgFR Jan 25, 2008
    from yesterday we've had excatly the same problem :
    it said there was a jam. we checked everywhere and there was nothing we
    could see. We removed the ink cartidge, turned it off and back on. Then
    From this moment we only have the message "no paper pickup".
    It's a HP LaserJet 3055
  • Anonymous Feb 14, 2009
    The printer was working all right. I changed the Toner. Then the message came uo no paper pick up"
Hi , I just had a same problem with the HP Laser Jet 3055 printer at our office but I fixed it! try this:
Turn off the printer.
Open the printer door.
Remove the Cartridge.
Look down behind the cartridge, there's a small white roll. Try playing with it. move it back and forth. try emptying the paper tray and place it back in the printer.
Turn on the printer.
I did this and for some reason it worked! GOOD LUCK!
Posted on Feb 07, 2008
  • mrsmith421 Dec 03, 2010
    When looking for the small roller beyond the print cartridge, found a partially feed sheet of paper, but Paper Jam not reported. Removed paper and printer worked normally.
It worked! Thanks much!
Posted on Apr 22, 2008
2 Suggested Answers
SOURCE: No Paper Pickup
look on roller behind cartridge.  Most certainly there will be a very small piece of paper stuck in the rollers.  Take it out.  Printer will reset.
Posted on Jan 30, 2008
What does "Original Jam" mean and how do I fix it?
Your "original" document -- the document that you are trying to copy, has jammed inside the printer's sheet-feeder.
Remove all the pages of the original from the "input" tray, and then look for a "missing" page -- one of your original pages is "jammed" inside the printer.
Jun 10, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
HL-5250dn ona Bonjour network will not work with Leopard
have you already tried reinstalling the driver of the printer?
Oct 21, 2008 | Brother HL 5250DN Laser Printer
Indicating a paper jam on hp deskjet f340
As printer is able to make a copy. It seems that printer hardware is working fine and issue is related with false error message on printer software.
Please run "print diagnostic utility" to resolve the issue.
Click on above link to open the web page >>>> click "download" >>>> click "run" >>>> again click "run" >>>> click "diagnose"
This utility will provide a list of problems and options to fix them.
Please try. Wish for all success..
Apr 19, 2010 | HP Deskjet F340 All-In-One Printer
My Dell 1720dn constantly has paper jams. A
I am having the same problem, did this get resolved?
Dec 02, 2009 | Dell 1720dn Laser Printer
Hp j4680 says "paper jam"
Try this. Sometimes you get that message because a previous jam was never fully fixed.
Sep 29, 2009 | HP J4680 Office Jet All-In-One Printer
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
Printer will print first page and then jam
Lean your printer back a bit!
(put a book underneath both of the front corners).
This fixed it for me!
Mar 22, 2009 | Samsung CLP 300 Laser Printer
Carrier Jam(lexmark x5320)
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
When turned on only copy button lit and a red exclamation lighton
Try unplugging it and check for specks of paper inside the printer, then try to replug it from outlet and turn it back on. try if it will copy then try printing. Hope this helps
Dec 12, 2008 | Epson Stylus RX500 All-In-One InkJet...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
HP LaserJet 3055 All-In-One Printer Logo
3,668 people viewed this question
Ben Johnson
