Question about RCA P52937 52" Rear Projection Television
Tv colours need adjusting
There is three colours surrounding each person or object
    President:
  • 4,402 Answers
Convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 22, 2008
6ya staff
SOURCE:
What must the settings be for the colour , contrast ect ect on a hisense tv?
These controls are adjusted to give you a pleasant looking picture that suits your personal tastes. There is no right or wrong with these settings.
Sep 20, 2014 | Hisense LHD3204US 32 in. LCD HDTV
Appears out of fcous for the red and green colours with a red and green image surrounding all objects.
Look in menu to see if the set has a convergence adjustment in the menu--if older set and colors are skewed or 3d looking the convergence circuit needs repair---got a model number? If a Sony should begin with KP.
Apr 18, 2012 | Sony Televison & Video
The best picture setting
First adjust the contrast & then brightness in such a manner that there just picture detailing. Adjust these controls especially on hair details of the person in the picture. The adjustment should be soft on eyes. Colour shall be adjusted for colour of an Indian should look. If your TV has ambiance sensor, then there is no need to change the settings in day & night.
sonsunny
Jun 24, 2011 | Televison & Video
THE PICTURE IS NOT CLEAR A SHADOW BEHIND OBJECT, THE SCREEN IS OVAL
You most likely have a large magnetic source near the screen like a surround sound sub woofer or other speakers. also go into the tv's settings and have it auto adjust the convergence. should help
Aug 24, 2010 | RCA Televison & Video
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Samsung SRS TV
Have you attempted to go into the menu and adjusting the convergence.. Check in the menu and line up the bars. If this does not work it might need to be adjusted manually.
Thanks Steve
Mar 27, 2008 | Televison & Video
Dvd hook up
Depending on what leads you have and what connections your equipment has depends on how you would wire it up for a basic setup you need a set of three male to male rca a leads consisting of a RED WHITE and Yellow plugs at each end. Now on the back of your dvd player there should be three female holes the same colou as your plugs and near those holes it should say input plug the leads colour to colour now the other ends of the lead plug into the section of your amp thats says dvd input with the same style holes as the dvd player. then you need to run another cable the same as you have just used to take the sound and picture to the tv you start of plugging one end into the amp where it says monitor or tv out and then at the other end of the lead will plug into the tv in A/V1 or A/V2 if the A/V1 is being used for a video player or camcorder Yellow is Picture Red is Right Sound Channel And White is Left Sound Channel so only plud the matching colours to each other or you will end up no better off hopefully this helped if you get stuck my email is [email protected]
Mar 23, 2008 | Pioneer VSX-108
Bad ghosting of all colours
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2008 | Samsung PCL545R 54" Rear Projection...
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
RCA P52937 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
