Question about HP LaserJet 1300 Printer
Fuser How do you replace the fuser on the hp 1300 and where do you buy it? I see the fuser film and see a fuser unit ($23.00) and assembly ($133.00) on hp website. Help. Thanks.
  • ebpet Apr 07, 2009
    ghosting is occuring on all printed sheets and from what i can gather from reading the comments and fixes recommended, replacing the fuser assembly or the fuser unit or rollers will probably fix the problem. i would like to start as inexpesively as possible by replacing the unit or rollers, but can't seem to find an outlet that sells them. any ideas or direction would be welcome. thanks
  • 89 Answers
You will only need the fuser unit. It is a little complicated but here it is. You need to remove all the covers, the several screws and a bracket. Here are some good directions.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201150,%201300%20Service%20Manual.pdf
Posted on Jan 22, 2008
How to reset fuser unit in printer hp laserjet 4250
turn the printer off for at least 20 minutes, then cycle power. If the 50.2 fuser error occurs again, you may need to replace the entire fuser assembly OR you will need to replace the power supply.
Dec 24, 2012 | HP LaserJet 4250n Printer
Hp printer laserjet 1300,its meking lots of nosien printing faintly,its also creasing papers
if the noise is like a plastic packaging its most likely the Fuser Fixing Film.
You can get it replaced at a tech with a compatible one or with a new fuser assembly.
Nov 18, 2010 | HP LaserJet 1300 Printer
1300 Printer prints roller marks only on one side. have tried cleaning roller & changing cartridge.
If it is not the cartridge check the fuser. Open the back access cover shine a light in and look for wear marks on the grey fuser film. If it is worn the fuser film is worn it should be replaced.
Jun 09, 2010 | HP LaserJet 1300 Printer
Paper jammed.sheet stuck approx 9cms out at top.
The problem is the fuser. Lower pressure roller is damaged. Possible wear and fuser fixing film.
can change throughout the whole fuser
RM1-0661-040 ---- HP LJ1010 220V Fuser Assembly
RM1-0660 ---FUSER - 120 Volt Fuser Assembly
or parts of this
http://www.precisionroller.com/search.php?q=hp+1010&x=12&y=5
FUSER - Lower Pressure Roller :  RF0-1002
FUSER - Fixing Film Replacement Sleeve : for hp 1010
good luck
Dec 13, 2009 | HP LaserJet 1010 Printer
Paper wrinkles on left side when printing
Fuser is worn out (specifically, the pressure roller).
May 19, 2009 | HP LaserJet 1300 Printer
4250tn print black spot
You either have a bad spot on the drum or a bad spot on the fuser rollers. Replace the cartridge first. If spot continues, take cartridge out and get inside with a flashlight. You'll probably find a piece of paper stuck to a roller.
Apr 04, 2009 | HP LaserJet 4250n Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Hp 1300
the fuser is delaminated , you need a new fuser unit.
Jan 22, 2008 | HP LaserJet 1300 Printer
FIXED FILM
Where about are you in the world as you can buy the fuser unit and get it fitted. There is nothing you can do to repair the machine you will have to replace the fuser unit.
Please mail back
Thanks J
Jan 05, 2008 | HP LaserJet 1300 Printer
1300 laserjet with smudges
sorry to say but it does sound like the fuser. you may not necesarily have to replace it. it could just need a good cleaning on the fuser rollers. it is best to let a repair man do it. if you want to try make sure fuser is cool. be very careful not to scratch the coating and do not touch roller surface with your fingers. Sorry I can't think of a home cleaner to use, you could try isopropyl alchohol. but I am sure you will find an image baked onto the upper roller will will need to be cleaned off.
Dec 26, 2006 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
349 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
