Question about Uniden TRU9280-2 Twin Cordless Phone
CHECKING MESSAGES HOW DO I CHECK MESSAGES AWAY FROM HOME???
First call your home number, when the answering machine picks up, dial 0 then the two digit security code. (You have to check the security code on the handset.) It will then give you voice prompts how to listen, skip and delete messages.
Posted on Jan 23, 2008
Need code to check messages from another outside phone?
did you look under the unit for a sticker with the code? Sometimes it is put on the unit.
Dec 28, 2011 | AT&T CL82409 Cordless Phone
How do i check my messages away from home, from a cell
http://www.uniden.com/index/manuals_results.cfm?cat=59
This is a link to the guides, look up your model number and down load the guide needed.
Hope this helps.
Ed
Apr 17, 2009 | Uniden DECT 6.0 Cordless Phone ID
Can't find booklet to help me in retrieving messages when I'm away from home
Here is the manual :Operating Instructions
Check page 43 : transfering calls
and answering system from page 36
Apr 15, 2009 | Panasonic DECT 6.0 Expandable Cordless...
How do your retrieve messages from home while away from home
Here's the manual:
29869GE2 Digital Answering Machine
You will need to set a security code. When you're away you can call your home phone and enter the code to retrieve your messages. Hope this helps.
Dec 29, 2008 | GE 29869GE2 Digital Answering Machine
Can't get messages when away from home
called the 800 # and talked to a person when they were open
Dec 15, 2008 | Uniden 5.8GHz Dual Cordless Phone
Checking voice mail remotely
for this model of phone, you perform the following:
1- Call the phone, wait for the machine to answer
----if the machine is on, it should answer within about 4 rings and begin playing your answering machine message
----if the machine is off, it will still answer after about 10 rings with a series of beeps
2- During the message (or beeps if it is off) press 0 and then enter your 2 digit PIN code. This should get you remote access to the phone. from there you can follow the menu structure that the phone tells you. If you never entered a PIN code, that's not a problem. the default code for this model of phone is 80.
you have about 15 seconds to enter a command, all commnds are two digit (01 through 10) and the digits must be entered within 2 seconds of eachother for the command to hold.
follow those directions and you'll be checking your messages in no time flat.
Jun 09, 2008 | Southwestern Bell (S60802)
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Dec 29, 2007 | Uniden DCT648-3 Cordless Phone
Retrieve messages away from home on a Panasonic KX-FPG381
You have to set a polling number, you WILL need a manual. Use your keypad just enter this number when you phone home
Aug 12, 2007 | Panasonic KX-FPG381 Plain Paper Thermal...
Uniden TRU9280-2 Twin Cordless Phone Logo
251 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
