Question about Frigidaire FGF378AC Gas Kitchen Range
Frigidaire FGF378AC Gas Stove
Stove knob shuts off oven at 300 degrees not 0 degrees
  • 23 Answers
There are 2 possibilities:
1) Are there 2 knobs to control the oven? If so, they may be switched.
2) Depending on the thermostat used, it may be possible to put the knob on upside down.
Posted on Jan 23, 2008
Bad smell coming from stove
Look In broiler compartment and check for signs of mice
Apr 06, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Got fire
check for grease build up where the pilots are located. are you leaving pans with grease on the stove ?
Feb 04, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Rebuilding old wolf stove
It is possible but you have to know how, top burners will be easier to do then oven, for top burner you will needed push button switch, spark module and electrodes. I never done the oven but it is possible. Have fun.
Jan 03, 2009 | Frigidaire FGF378AC Gas Kitchen Range
One stovetop ignitor doesn't work: the gas comes out, but no clic
there is a swich behing the knob that turns on the ignition, it most be replace. every burner has one of those swiches, when you remove the knob you can see it, it's white in color about an inch long.
Dec 03, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire 337 range
regulators are where the gas line coming from the house behind the stove conects to the stove. it's square about 2 inches by 2 inches.
Nov 24, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire gas range makes loud whirring sound when oven is set above 250
You don't give a lot of info here (like if the range was converted from natural to LP, or if the burners are OK, or if it is a self clean model and how the broil works, etc) and I can't guess all that, especially because a lot of people post under whatever model pops up when they enter a key word while posting a problem, but,..........
Any range that was professionally installed should have been tested for proper burner and oven operation by the installer before they left. Call the installer back and let them know you are not satisfied.
Nov 02, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
{ easy off } and { oven off }.this are the best cleaning solutions for the grease inside the oven and cook tops. any market will have any of this,or hardware stores. Warning can not use on aluminiun it will turnish it or numbers on knobs.
Feb 13, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Oven Knob all of sudden shuts oven off at 300 degree mark not "off"
The inside part that locks the shaft to the controls is loose.
it can be fixed. but will take some ingenuity.
you will have to take the control completely apart to get to the loose area, walmart has some plastic glue that comes in a 2part tube for 4.00 that can repair most plastics and provide fill a the same time.
or just order another control if you can find a place that has it.
Jan 22, 2008 | Frigidaire FGF378AC Gas Kitchen Range
sl, because it't happening to both broil and bake the first thing I would suspect is the temperature probe. You should ohm it out. You can do this either at the board or at the harness connection in back. For the board, remove the back panel, there should be a 8 pin connector to the left of 3 relays. On the harness measure the resistance of the wires going to pins 1 and 2. On the shemantic it shows them being the 2 on the bottom. Should read around 1100 ohms at room temp. If you cant get a good reading on it there, Remove the probe from the inside oven, remove the screws and pull it out until the harness connector comes through, disconnect it and ohm it out from there. I don't think that both ignitors would fail at the same time so Im leaning toward the probe. Catriver.
Dec 11, 2007 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire FGF378AC Gas Kitchen Range Logo
120 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
