Question about Zenith SY2572DT TV
Power Television sounds like it wants to power on, but doesn't. Hopeless? If it can be repaired, is it usually very expensive?
Hi, I have a Zentih Model Number SY2572DT and I can not get any channels except 2 thru 13. I tried using the menu, but cannot find where to change to cable from antenna. Can someone help?
Posted on Jan 28, 2008
  • passer Jan 28, 2008
    Hope someone can help with this problem. Thanks.
LG RF 21FA20PQ SET DEAD
Probably due to a defective power supply. The power supply is repairable, but usually not worth paying a repair tech to do the job. Less expensive to purchase a working unit.
Apr 23, 2014 | Computers & Internet
Turns off on its own
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 30, 2011 | Envision L32W761 32 in. LCD TV
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
I have sound, all remote functions work, I have no picture
These sets have a problem with the backlight circuitry which causes the set to operate properly( tune channels, sound ok, etc..) but there is no picture..this is likely caused by the filter capacitors in the inverter power supply circuit which , over time, tend to either leak or lose thier esr value. The repair usually consists of replacing a few electrolytic capacitors and possibly a resistor or fuse. If you can find someone who repairs these near you, you may want to get an estimate...theoretically, the components are not very expensive for this repair., and takes little time..so look out for scammers
Mar 26, 2011 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Power supply is not working. Replaced power cord with new one and it still is not working. What do you think is wrong and cost for repair?
50-inch is always expensive. If there is no indication of the work is probably defective power supply or a problem with it. usually capacitors. but if capacitors and other circuits may be faulty.and then becomes very expensive
Jan 28, 2011 | Fujitsu Plasmavision P50XHA30WS Television
Heading out the door to work, I accidentally grabbed the wrong power supply. My Coby CD-TV153, which requires a positive center, 13VDC power supply was plugged in to a NEGATIVE CENTER, 9vDC power supply...
its not always fatal depends on what is damaged internal
however it may be cost effective to just replace the unit
the power circuit in the tv needs to be checked and see what if any thing is damaged it then you can make a asesment of repair
Nov 04, 2009 | Coby CD-TV153 5 in. Television
TV DOES NOT COME ON AT ALL
Bad power supply. Symptoms: No display at all, no power indicator light, no sound from speakers, momentary popping or clicking noise, "burnt electronics" smell. Typically caused by failed capacitors. Can be usually be repalced and continue to have working display for a long time. Repair: Replace power supply. Super cheap when it's just a couple of bad capacitor to medium expense when repalcing whole power supply unit.
-=/ Daft Tech /=-
Oct 22, 2009 | Toshiba 23HLV85 Television
No power no picture no sound Astar LTV 20PW
Hello friend,
Your tv can be fix, I am the right person could help you fix your tv.
please call 323-767-6030.
Jan 03, 2009 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
My new Hitachi LCD L32H01U
If you know just a little about electronics I can suggest several things. If not you'll need a tech...
Forst check F901 in the power supply, if it's open replace it and D902. If not open, check R964 for broken solder connections. The power supply in this unit is very commonly the culprit of a dead unit as you're describing... It's not usually an expensive repair for a qualified shop if any of this sounds a bit beyond you...
Take care Juliet and let me know how it turns out.
Bill
Nov 15, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
