That means the player is sending a progressive scan signal to the television and the television cannot deal with it..Disable progressive scanning in the dvd player.
well on your memorix dvd player you will get a orange triangle that says pscan (progressive scan) you will go to the back of you dvd/vcr and on the right hand side you will see a switch to turn on and off the pscan you will switch it off and you will be set to go
I work for Memorex technical support. Our customer service phone number is 1-800-919-3647.
On the back of your player you should see a switch that can slide back and forth that's marked PSCAN. Slide the switch into the opposite position from which it's in now. The should solve your problem.
If
you feel this solution doesn't deserve a good rating, please let me
know why so that I may better assist you. If there is anything more I
can do to help, I will!
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
had the split screen with pscan triangle looked for the button on the back, no button but on the remote was a button named V.MODE pressed it and everything back to normal thanks for the help
