Question about Panasonic CT-27SX11 27" TV
Dysfuntional TV/Video selection
The TV/Video selection choices (TV front as well as remote) on my unit are restricted to 1 (television) and 3 (front a/v ports) only. There is no Video 2 selection for the rear ports...S-video, composite nor component to access my DVD player. Please help.
  • 64 Answers
Thats a tricky one.. If there is no restriction or parental restriction setting in the menu then i would say that something went out on your back A/V panel... and probably not easly replaceable. probably would be better off looking at a new TV and hand that one down to the kids or put it in a shop or another room in the house.
Hope its a menu setting.. good luck.. let me know what you find.
Posted on Jan 22, 2008
How to switch tv over to play games on wii
press menu button and look for source or input and manually do it onscreen, different buttons scroll through choices, enter button selects choices
Aug 20, 2012 | Toshiba 30HF66 30" TV
My tv is stuck on the video imput for my Wii and none of the front panel buttons work
Try to see if any of these four methods will work.
Sanyo TVs
1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote
2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV
3. Press TV/AV or INPUT SELECT on remote
4. Press SETUP, choose TV/AV, switch to AV
Sep 25, 2011 | Panasonic TH-42PX60U Television
My JVC model AV27330 has a constant blue screen. I can go thru Video 1, video 2, video 3 and then says chn 04 but should be 03 - when I push channel button down channel 105 shows or the other way channel...
You need to use the original remote and call up the customer menu; select auto program or channel program and see if reprogramming will help.
If no JVC remote you have only one other choice----connect a DVD or VCR to one of the video inputs and see if the set functions that way.
SD TECH
Aug 09, 2010 | JVC AV-27530 27" TV
How do you get a playstation 3 too work on my ilo tv
Depending where you hook it up... in front or in the back...use your remote and click on the input select button. That will turn it to video 1, video 2, ect... I believe the front connections are video 2 and the back is video 1.
Jul 18, 2009 | iLO IWT3206 TV
Can't receive pic and sound with converter box.
Connect the RF output of the Magnavox to the VHF/UHF (ANT) input at the back of the TV. Select channel 3 or 4 on the TV. An alternate is to connect the component output (red-white-yellow) to the Audio/Video In jacks at the front of the TV (the red or the white would be left unconnected) and use the TV/Video button on the remote to select that input.
Jul 08, 2009 | Toshiba 13A24 13" TV
I have GE XS Stereo Commercial Skip Model 27GT619
  1. On the front of the TV press the MENU button to display the MAIN MENU.
  2. Scroll through the choices using the VOLUME up and down buttons
  3. When positioned on the selection you want press the MENU button again.
  4. The first SETUP screen displays, asking you to select a language.
  5. Scroll to the desired language ENGLISH, FRANCAIS or ESPANOL and once it is highlighted in green press the MENU button to make finale selection.
  6. A SETUP screen appears asking if you would like the TV to search for all channel
  7. 1. Yes
    2. Skip this step
    3. 0 Exit
  8. Complete the SETUP routine or skip any of the steps and return to them later.
This information is from the User Guide that came with our set. Good Luck.
Jun 11, 2009 | GE 27GT271 TV
Cannot get 27" jvc av-27530 tv to recognize playstation 2
Do you have the remote? You will need to cycle through the inputs to get to video 1 or 3. You might have the buttons on the front of your tv that says tv/video or tv/vcr. If not go down the channels past 1 and it might automatically switch through the video input selections. For any of these solutions have the PS2 plugged into video 1 and turned on. Hope this helps.
Jan 04, 2009 | JVC AV-27530 27" TV
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Video input selection remains displayed - can't get rid of it
The solution to your remote problem is to go to wal-mart and when you go through the check out lane there is usually some last minute items. there is a silver remote that is usually hanging in those aisles and that has been the only one I have found that works.
May 20, 2008 | JVC AV-27530 27" TV
Panasonic CT-27SX11 27" TV Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
