Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Vertical black bar on plasma screen
42PF5321D philips screen has a black bar apx 2 1/2" thick on left side of screen 3" from edge all inputs it also blacks out the menu
  • Jeffx2x Feb 13, 2008
    Just happened to my TV. i am pissed. Post a solution if you have it.
  • Philips Master
  • 1,689 Answers
This is usually caused by a screen addressing fault. The location of the fault can be on the main screen driver board, or in the area for the screen address processing. It can also be matrix fault with the drive to the screen.
You will have to give the set out for an estimate. From this you can make the decision if the set is worth to service or not.
Jerry G.
Posted on May 19, 2008
  • Isaac Gborglah Jun 29, 2013
    how much it would cost me to solve these problem
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
On a 58" diagonal plasma, I have an approximate 3-1/4" wide pink vertical bar in the lower left corner of the screen. It does not go all the way to the top of the plasma, it stops mid-way on the scre
There is some connection defects. If you wish to know more about these kind of fault to plasma displays, check this link. There is illustrations to compare with, which cannot be included by this window.
Feb 25, 2013 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
While watching our 42 inch Philips Plasma tv the other day, a vertical black bar showed on the screen. Based upon the fact that it appears no matter the input (HDMI, composite etc. We turned off the tv...
If you get the black bar and it is vertical, not horizontal and it is on every input, your panel has failed. It is more economical to buy new than replace the panel. Try a Sony. Mine rocks.
(If the bar is horizontal, it may be an empty closed caption box)
Aug 09, 2010 | Televison & Video
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Black line on TV
Try cleaning and reseating the ribbon cables on the XR board.
Mar 08, 2008 | Televison & Video
On Philips LCD and Plasma TV's you can center the picture left and right and also vertically. Use the round joystick in the center of the remote to see of you can shift the image to the left.
Dec 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Black vertical bars on left side of screen
when you are using DVD, there is no problem directly indicate the problem is in video game. You can try by changing colour system of the TV (PAL,NTSC etc..) or the video game to fix the problem.
Nov 29, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
387 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
