Question about Saeco Royal Professional Espresso Machine
Machine not working!!
Two days ago a friend of mine accidentally put water into the beans compartment and pressed the button for espresso! It made one cup, but then stopped grinding. I have thoroughly cleaned the container and even dismantaled the unit inside to clean it and dry it thoroughly. It´s been put together exactly how it was again. It was grinding coffee again without any problems, but then the water only came out in a few drops at a time. Now I only get a 'watertank is empty' sign (even when the tank is filled)!! I have left the magnet inside the water tank, so it's definitely not that! How can it be fixed?
  • 2,039 Answers
The circuit board is probably fry when you put back the grinder the ajustment are sometime tricky maybe it grind the coffee to fine that why it doesnt drip good try that and if everything work fine except the water level so be it there probably something fryed in the board good luck cheers
Posted on Jan 22, 2008
I accidentally put water in the grinder will it dry out
no,will not dry .You have to take off the beans canister and get out the grinder knife to clean it.
Jul 11, 2014 | Saeco Magic Comfort Plus Espresso Machine
Put 2 spoons of coffee in the by pass dozer
The machine is made to grind WHOLE bean. Why are you trying
to bypass the grinder? The machine measures both bean grinder
and water with timing.
May 07, 2014 | Saeco Vienna Espresso Machine
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I cleaned my delonghi magnifica and now nothing works. neither water or coffee comes out.it is just out of warranty unfortunately. help!
have u switch it on on back cover ??? ummm make sure u have the bucket sat in correctly .....and tray is in properly... have you snapped off the peg on the rear of the bucket for wast ?? its located rear of bucket. bsc appliances bristol 07779933829 postal service too.
Feb 08, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Impressa F9 Espresso Machine: First the coffee grinder stopped working -- the re...
i always start by turning machine off at the power point and rebooting machine. i have a Jura but not your model - try pulling out the drawer and container that collects the used ground coffee and with a damp cloth put your hand up in the machine to the shute and wipe away any residue that might be left there. good luck
May 05, 2010 | Jura Capresso Impressa F9 Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Dec 16, 2007 | Saeco Royal Professional Espresso Machine
The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Oct 06, 2007 | Saeco Magic De Luxe Espresso Machine
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Saeco Royal Professional Espresso Machine Logo
137 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
