Question about Denon AVR-2307Ci Receiver
AVR-2307CI, Auto Room Set Up problem
I have the system all connected up and am trying to run the AUTO ROOM SET UP configuration to set up my speakers. It runs through the program, while the LCD displays which speaker its measuring, there is loud static noise, then the LCD display shows, ANALYZING the particuliar speaker. Once it finishes, I am getting a CAUTION! PHASE display on the LCD display. There is nothing in the book about it, and I dont think it finishes the auto room set up. I really want to configure the speakers so its ready to play, and I am pretty sure all connectrions are correct. Any suggestions?
Regards,
Kris Smith
  • sakmett Jan 22, 2008
    Not the case. I have checked everything, and in a closer look at the error message I am getting, it says that all the speakers I have hooked up are supposedly out of phase. I know thats definitely not the case. I have gone through everything and made sure all connections are correct, and that all polarities are correct, however I am still getting the error message, CAUTION! PHASE, FL/FR, SL/SR.
    I just continued on, and skipped over the error message. I talked to some Denon guys over the phone, and they said there are speakers out there that for some reason send a signal back to the reciever telling it that the polarity is wrong. They told me to just skip it for its harmless, and the reciever will remember the test even though it says there is a CAUTION message. Also, they said it could be that at one point when hooking it up, the polarity was reversed and the error message was displayed. They said there may be an internal memory that might have to be reset or cleared before if will conduct a new system test or check. Anyway, by skipping over the CAUTION message I can store the set up test into the memory of the reciever. It appears to have worked, as the surround sound is working properly now.
    Thanks for all the help, this is a pretty damned cool website. I will have to bookmark this for later reference!
    Thanks a bunch again.
Guest was me nick djnick
Posted on Jan 22, 2008
What settinsg are u in does it do it on all prologic modes or just digital cable ? what kinda speakers are uusing what brand and model ill also get a manel on your av see if it says talks about that polirty problem il keep reserching
    Genius:
  • 1,067 Answers
Maby out of phase cheak wiring red on postive black on negitive wires ones out of phase
  • nick helpap
    nick helpap Jan 22, 2008
    also cant u just skip that test area does it work with out doing that ? skip that then and set it yourself distnace away from were u sit back chs 10 ft fronts 20 ft center 20 ft ect ok thats all thats doing
  • nick helpap
    nick helpap Jan 23, 2008
    great so glad it worked mark me as fix ya then ok i sighned in as guest those wont count for my score ok have to rank me under this name ok glad u skiped over it
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
I set remote on "cool"
Hi there, this is a 21/2 ton split system. You can lower it to 68 degrees, but I wouldn't go any lower then that.Auto is for the fan only, it cycles on and off in the auto position, and in the on setting it runs all the time even when the cooling stops just to circulate the air. You can try and leave it in the on not auto as this may help the room stay cooler. Please keep me posted.
Shastalaker7
A/C, Contractor.
PS, if the remote does not say on, and just says auto and cool, set it to auto.
Jun 09, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Denon 2309 and i hooked up a pre amp to use for my multi room. the issue i'm having i hear the radio station for my multi room, but when i put on my ipod. my multi room still plays the radio...
The iPod signal has to go to the pre-amp as well as the living room amplifier.. You'll have to move the iPod connection so it replaces the radio signal to the pre-amp as it does with the living room amplifier.
Nov 22, 2017 | Denon AVR-2307Ci Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Denon avr 3805 2 zone configuration, I added optical sound from TIVO and now zone 2 is not working. I did the test of the speakers and they all work. I have configured the main for 5 channel stereo.
Zone 2 needs an analog input to work, if you pulled the analog from tivo, put it back on. Digital will not pass on zone 2. If your analog is still connected as well, go into your receivers settings for audio and select "auto" not "digital" Check the settings on tivo as well. make sure it's audio output is set to "auto" if available. If it's not, it's default is "auto" and will output simeltaneously on all outputs. Hope this helps. If you need more help, post a comment and I will help some more.
Jul 05, 2009 | Denon AVR 3808Ci Receiver
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo TX-SR605 Receiver
Denon Avr-1803- multiple room audio difficulties!
it is true pre amp check your cables and confirm in (avr-1100)that you select the right input.
May 27, 2008 | Denon AVR-1803 Receiver
Can't get Zone 2 output
are you useing an onkyo amp?Iff so tell the amp to switch on zone 2 then set the volume for that zone and the source you want to play.
Apr 22, 2008 | Denon AVR-3805 Receiver
Speaker setup
Need dimensions of the room...accordianman
Oct 31, 2007 | Arcam AVR-200 Receiver
Open Questions:
Denon AVR-2307Ci Receiver Logo
366 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
