Question about Fuji FinePix S5000 Digital Camera
Battery cover Hi The battery cover on my Fuji S5000 is broken so the batteries wont stay in, hence making the camera useless. its not actually the cover its the 2 prongs on the camera body that have snaped, what can I do?
  • 667 Answers
I had a look at my S5000 and see what you are talking about. Those tabs are part of the inner shell, likely expensive to replace if even cost effective. In the past, I have cut the broken tabs off, leaving a flush surface. I then drill small holes and insert large head screws that I file to match the door tabs. It does require some finite work but is possible without disassembly of the camera.
Posted on Jan 23, 2008
  • Linda Estridge Jan 21, 2012
    I dont understand what holds the door? I have the same problem. Door is not broken but one of the plastic pieces on the body of the camera. can you explainn in more detail or attach picture.
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
The battery cover on my Fuji S5000 is broken so the batteries wont give an contact , hence making the camera useless. The number of battery holder is FZPO1702-100.Give me hint where I can purchase this...
Hi
you can only find it as a used in normal price
you better check on ebay for the camera and just get the
part you want
the cost of it is to high in market
Jan 09, 2011 | Fuji FinePix S5000 Digital Camera
Hi my name is Charles. My batteries cannot stay in
See post:
http://www.fixya.com/support/t1747423-fuji_finepix_s5000_battery_door
Elastics, sticky tape etc etc does not work.
OZwombat has neat solution by making a bar attached with a screw in the tripod connection
604foxtrot replaced half the case which came form a used (broken) camera from ebay.
Mar 26, 2010 | Fuji FinePix S5000 Digital Camera
Broken cover on a Fuji FinePix S5000
I think it will stay closed with painters tape or gaffer tape. this type of tape is blue or black. it is strong but not super sticky. I also have the same camera. my battery cover broke after the strap got stuck on a door handle to my office and the door kinda crunched it.
Apr 05, 2009 | Fuji FinePix S5000 Digital Camera
I have a Fuji FinePix S5000 and the battery door catches (on the body of the camera) have broken off. Replace complete body assy??? I am sure mine is not the only one. any help appreciated.
I had this problem also (see below).
After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
Mar 05, 2009 | Fuji FinePix S5000 Digital Camera
Doesn't power on
If the batteries did leak out, then you could clean the battery contacts with contact cleaner and a pencil eraser. Providing the contacts are intact, you might get it going again with new normal AA batteries.
Dec 23, 2008 | Fuji FinePix S5000 Digital Camera
Fuji S5000 Shuts down
Battery problem, might need new rechargeable battery as old one can't hold charge no more.
Nov 06, 2008 | Fuji FinePix S5000 Digital Camera
Fuji S5000 mode switch?
That looks very much like the slector switch has slipped inside and is out of position.
That can be fixed if the actual and very tiny switchover pins are not broken.
I have repaired one switch actually with parts from a S3000.
Works ok but extremely fiddely.
Otherwise it is a replacement of the small switchover board, which sits on top of the battery compartment.
Problem being: Fuji will not sell parts to us.
Good luck
germander
Mar 10, 2008 | Fuji FinePix S5000 Digital Camera
My S5000 wont switch on to shoot mode
My mode awitch detached.
A fuji fix cists $130.
Where can I get help with assembly?
Alan
Sep 16, 2007 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
421 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
