Question about BenQ FP737S-D 17" LCD Monitor
LCD monitor went blank
My BenQ LCD monitor went blank when I was busy with my work. It is not my tower because I tested it with a different monitor. Normally if you power up a monitor, it displays the following massage “No Signal Detected” but myne doesn’t anymore! Please Help.
Makgopelo Mokgotho
Makgopelo@gmail.com
  • 7 more comments
  • kgops Mar 01, 2008
    Yes the power LED remains on.
    and its
    Model: Q7T3
  • sweetblonde1 May 21, 2008
    my monitor keeps going black every few minutes its getting worse by the day can you help me fix this problem it starts to flickers before going black
  • MannyRay May 27, 2008
    Same monitor same problem, screen just went blank and power light stays on. Nice monitor, need to fix it fast. Looking for a solution, can anyone help? Please?
  • EliasA Jun 01, 2008
    I have a Benq FP737s Monitor that is blank also. I have opened it up and checked the fuse - all ok. I have managed to get green and orange lights out of it - but nothing else. Can you help please ?
  • tiekie Jul 08, 2008
    Seems a generic 17" Benq problem - I have an FP737S doing exactly the same. Green light/yellow light on power button, otherwise nothing.
    Anybody got it fixed by resoldering those transistors as suggested?
    Stephan - BC
  • Tylou Jul 28, 2008
    same. Green light/yellow light on power button, otherwise nothing.Screen just went blank.Can you help me fix this problem.
  • ldisanto Aug 25, 2008
    I have the same monitor and we checked the tower and replaced the video card and still the monitor is black what do we do to fix it can you help thanks
  • Anonymous Feb 01, 2009
    BenQ T2200HD monitor remains blank at power up "no signal detected"
    yellow LED light on
  • Anonymous Mar 10, 2009
    I've changed all the components(transistors,fuse) and still gets black screen, could it be the lamps? Mine stays with power led on.
    Champion:
  • 220 Answers
Which model is it?Does power led remain on?
Samir
Posted on Feb 25, 2008
  • Samir  Shah
    Samir Shah Mar 02, 2008
    Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
    Samir
SOURCE:
My monitor is not responding. I have a blank screen and my power led is flashing green, none of the front monitor buttons are responding, not even to turn of power. Cannot access menu as I have blank,...
Hi Cat, You can try removing the data cable of your monitor, the one connecting to the back of the tower/computer. If there are no issues on the monitor, normally you will be getting the power self test which is indicated by three vertical colors on the screen (Red, BLue, Green). If you dont see the power self test, it may be a problem with the monitor. YOu may want to try using a different monitor to isolate issue if available
Oct 27, 2010 | Acer AL1912 19" LCD Monitor
I have a brand new shiny benq v2210 but no drivers or install disk. How do I install it. t thanks
I just went to the BenQ website and found the following:
Please visit the BenQ website at www.BenQ-eu.com/serviceandsupport/ to download the appropriate LCD Monitor drivers, alternatively you can also use the standard plug n play monitor driver in windows.
First I did Google search for BenQ
> www.benq.com
> clicked on support
> chose USA
> Knowledge base
> FAQ LCD Monitors
> first question: I don't have the driver for my LCD monitor, what should I do?
Also, I found the BenQ phone number (1. 866. 600.2367) that you can call during Monday to Friday business hours which are: 8:30 to 5:30 PST
I hope this will help resolve this for you
cmilton111
cmilton111@gmail.com
Feb 26, 2010 | Computers & Internet
15 inch lcd monitor Benq Model Q5T3 has a blank screen has power but screen just black. Can let it sit for a while and sometimes it will stay on for a few minutes but goes black again Thanks
It could either be a driver issue on your system, or a problem with your video card. Turn off the computer, open the case, remove the video card, re-seat it in the slot securely, close up the system and power it back on. If the problem still happens, update the display adapter driver, if it still happens, try a different video card or monitor. You could even test your monitor by plugging it into a system that you know doesn't have this issue.
Feb 22, 2010 | BenQ Computers & Internet
Screen just went blank and power light stays
THE PWER TRANSFORMER MY NEED TO BE CHANGED, DUE TO A DECREASE IN AMPERAGE.
Jul 01, 2009 | BenQ FP71G+ 17" LCD Monitor
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
BenQ LCD DV3250
Hi...there,
Well, have you try plugged into a different port like a DVI port. If you don't got one try replaced with another VGA cable.
Sep 26, 2008 | BenQ FP71G 17" LCD Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck Housecall101@aol.com
Jul 24, 2008 | Star Logic 17" LCD Monitor
Benq 17"Lcd monitor fault
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq fp737 17
How old are the monitors?
Normally backlights last at least 30,000hrs of working.
Normally problems on Inverter board transistors near yellow inverter transformers.
Samir
Nov 28, 2007 | BenQ FP731 17" LCD Monitor
Unexplained Blank screen.
Looks like your Power Supply has gone Kaput .. Usually it is the Electrolytic Capacitors on the Power Supply Board, try a new one, or replace ALL the Electros with same or better ones.
Jun 21, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
3,299 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
