Question about HP LaserJet 3030 All-In-One Printer
Jam in fixing delivery output
It jam when the trailing edge of the paper goes out of the delivery roller
  • 96 Answers
Try to check the delivery roller there's a small roller will lost.
Posted on Jun 05, 2008
6ya staff
SOURCE:
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 21, 2011 | Samsung CLX-3175FN Printer
Canon IR3530 jamming
Hi, lets go from begining:
1) Remove rollers from lower cass, and put them on first cass. Use fresh paper too. - Does it helps? try abaut 50 copies.If helps replace rollers.
FB6-3405 x1, FC6-6661 X1, FC6-7083 X1
2) when you open right lower door and right door you will be able to see axis with two small rollers.Clean it verry well, use alcohol.
3) On lower right door there must be metal plate for pressure on delivery roller, if there is no plate, put in each corner some tape or filc 2-3mm thick, wich will add pressure on plastic paper cover wich guides paper on delivery roller.
4) Does your jamed paper have any anomalities on itself, like: look like accordian, small wrinkles,...
If yes, check separation plate on fixing unit, pressure of rollers ( between fixing film and press. roller - NIP CHECK ).
5) Beaneath drum you will see small plastic sensor flapper - is he worn out? This is paper registration sensor, if he get in first position before the paper pass him you will get jam code.
Note:
Try to flip paper in cassete, up side down, and try then. If then works, the problem is in moisture on paper.
Hope that helped
Jun 29, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Blur about one inch from trail edge 2270
Do you hear any kind of a thump thump noise when the machine is running? These machines flat spot the fuser rollers easily and this will cause a blur line towards the trail edge of the copy. This is because the trail edge of the paper is still having toner applied to it when the paper is going thru the fuser. When the flat spot "lops" over itself it puts a quick yank on the paper and creates the blur. If you are hearing any kind of thumping noise this is the cause and you will need a service person out to replace the pressure roller in the fuser.
Good Luck and Thank You for using Fixya.
Mar 16, 2010 | Canon imageRUNNER 2270 Copier
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
How do you stop paper jamming on a belt sander
there is a knob that moves the front roller [rotates] the roller side to side to center a moving belt - the grit belt. the roller has a slight bevel from the center out to the edge. both edges. use the trigger to start the belt in short spurts and move the knob. eventually you'll get the belt to track on center.
Oct 21, 2009 | Tools & Hardware - Others
Ruppled printed paper cannot exit output tray
you need do follow steps:
1) check fuser unit, the fuser hot roller is hot or not? if not the fuser heater fail.
2) check hot roller should spin with the pressure roller which is against hot roller, and check there is no gap between them, and also nothing pieces paper obstruct there, because if it losts pressure balance that jam should be occured there.
3) check the output roller after fuser unit(if there is), check them are spin or not, this roller kit use for pull the paper goes out the tray. if not spin means the roller drive belt or gear loosen.
3) check paper sensor that is micro swtch around pulling roller or output area and to clean it (could be a optical sensor).
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Samsung ML-2510 Laser Printer
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Assembly
Mar 19, 2009 | Canon iR 2020i Laser Printer
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
Printer
check the trails for paper pieces, and then clean the rollers..make sure that the paper is clean and 'riffled' meaning run your fingers through the edge of the paper..
check your computer warranty here 4 FREE
Feb 27, 2008 | Lexmark All-in-One Printer with PictBridge
HP LaserJet 3030 All-In-One Printer Logo
59 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
