Question about Nintendo Wii Console
Wii not working
Cursors from remotes not appearing on screen, have changed the batteries and got new sensor but still not working. have also tried re syncing my remotes. help!
I have followed all the steps many times and I can feel the console working as it vibrates when I press the buttons but even when I turn the SKY on and off, and all the other links like DVD the Wii does not come on the screen even when I manually seek the channel...any thoughts
Posted on May 14, 2008
    President:
  • 4,402 Answers
Have you unoluged and plug it back in?
also make sure sensor bar is plugged in all the way,
Posted on Jan 22, 2008
Wii cursor not appearing on screen
Step 1:
First we should try to identify whether it is the sensor bar, The Wii, or the remote itself. So, let's start off by trying out the sensor bar. I would recommend you putting two (decent) sized LIT candles on both sides of the sensor, or try simply cleaning off the sensor. If the candle trick works, you have a bad sensor and need to buy a new one. If nothing changes and you're still in the same boat, then we'll try to see if it's the remote.
Step 2:
For the remote there's not too many things that can go wrong it, but we'll see if it's the remote. What you wanna do is see if the if the Wii remote has a dirty top to it (black thing on top). This will cause the IR camera to not be able to locate the sensor. If this fixes it then you'll save some money, but if it doesn't we'll try something else. Now, what we got might be a bad IR camera in which you have to buy a new controller (I suggest trying some neighbors remote or a friends to make sure this is the problem). Another thing that might be a problem is any secondary IR light source will cause interruption with the communication from the sensor to the Wii remote, but I highly doubt this is your problem.
Step 3:
Now, if all of these fail it is more than likely something with your Wii console and I would highly recommend you contact Nintendo Customer Service http://www.nintendo.com/corp/contact.jsp for they might have more knowledge than me about that. I hope that this helps you out!
Apr 05, 2013 | Nintendo Wii Video Game Consoles & Games
Tip
Wii Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them.
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu.
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired.
on Mar 04, 2010 | Video Game Consoles & Games
My console turns on via remote. I can push the left and right arrows but I am unable to select anything on the main menu. I have changed batteries, and tried different remotes. No change. Any suggestions?
Do you mean that no cursors appear on your screen? You most likely need a new sensor bar. The button presses are transmitted via wi-fi directly to the wii, but the wiimote's position relies on infrared transmission to the sensor bar.
Mar 29, 2010 | Nintendo Wii Console
Cursor hand will not show up
Make sure you do not block either the sensor bar or the sensor on the wiimotes. Check all your connections in the back escpecially the sensor bar. If everything is all set you said it worked for your new wii system so im assuming your old one has issues. try all these out and tell me how it works out
May 25, 2009 | Nintendo Wii Console
Wii remotes want to point at a wall light
well if u keep them on the charger for to long u need to get new ones cuz it will shorten the batteries on and on so buy new ones k!
Mar 25, 2009 | Nintendo Wii Remote Controller
Cursor will not appear on screen
make sure your sensor bar is connected to the console! properly aligned in the centre of t.v! also reconect the controler by: open the sd flap on front, press red button, remove batt cover of remote and press the connect button! this will resync the remote! also check battery's!
Jan 04, 2009 | Nintendo Wii Console
Wii cursor
try to resync the remotes.
Jun 27, 2008 | Nintendo Wii Console
Wii Cursor Does Not Appear
I had the problem where the cursor worked on the main menu screen, but disappeared once you entered any of the channels or a game. For me the problem was a faulty sensor bar. You can check if your sensor bar is working by focussing a digital camera on the bar as if you were taking a picture of it. In the viewfinder you should see 5 blue lights illuminated on both ends of the sensor bar. For me, only one side was illuminated. The sensor bar had to be replaced.
Dec 26, 2007 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Wii remote controll
Buy a new sensor bar. None of my 5 Wii remotes had a cursor on screen so I bought a new sensor bar and it worked fine.
Nov 12, 2007 | Nintendo NES Remote Control
Nintendo Wii Console Logo
260 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
