GE Zoneline 2100 heater/ac won't heat/doesn't shut off
I have a couple GE Zoneline 2100 units with different problems:
One unit blows cold/hot air at the same time when set to heat. It doesn't ever shut off either...I have to unplug it...either in heat or cool mode.
The other unit was working alright with the switch messing up a bit. Now it seems the switch is working but not heat is coming out in the heat setting. I've tried unplugging the unit and plugging it back in but that didn't fix it.
I don't know how old these units are but if possible I'd rather fix the ones I have rather than buy new ones as I'm in a rental.
  • 3 more comments
  • Anonymous Oct 03, 2008
    THIS HAPPENED AFTER WE CLEANED OUT COILS
  • Anonymous Oct 10, 2008
    My GE Zoneline 2100 works fine, except it won't shut off either. I also have to unplug and leave it unplugged until I'm ready to use it again.
  • Anonymous Nov 06, 2008
    I HAVE THE SAME PROBLEM AS SHELLY1962. CAN YOU TELL ME WHAT PART I NEED TO FIX IT. THANKS. CH
    I HAVE THE SAME PROBLEM BLOWS HOT AIR WHEN ON AIR CONDITON SETTING, WE HAVE TO UNPLUG TO CUT IT OFF.
  • Anonymous Mar 04, 2009
    I have a GE Zoneline 2100 with the same problem! When I want to turn it on or shut it off, I use the fuse box.
    Problem Solver:
  • 4 Answers
Well, it's been almost 4 years since this was posted, but it's the selector knob. these things are HORRIBLY designed (the selector knobs) very easy to break if someone pushes it to the side too hard.
ASSUMING when you cleaned it, you didn't get the controller knob wet, which could cause heat and ac to come on at the same time. If after a few days, it's still the same, it's the selector. I've replaced a million of them (ok, not really a million, but, a lot.)
Posted on Mar 10, 2012
I have 2 of these units Zoneline 2100 and both of them continue to run constantly no matter what setting I have on. My electric bill is outragous and I've cleaned the vents. I only rent this place so what should I do? It runs for a couple minutes, shuts off for a minute then comes right back on....ALL day!
Posted on Jan 13, 2010
The problem is with the switch. You can buy the replacement switch board (~$70) and swap them out. Or if you just replace the actual switch on the board for only a few dollars, but this requires some soldering.
Posted on Mar 20, 2013
  • 63 Answers
Unplug them and wash out the condenser coils outside then check them again. See if there is any change.
Posted on Jan 25, 2008
Heater not working just blowing cool air
hit the easy button
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 08, 2018 | GE Heating & Cooling
97 Nissan Maxima heat still blowing when AC is on
Well thinking about the problem there e a flap in the vent pipes to shut off theatre and ac unit perhaps something has got in the pipe and stopping it closing or perhaps your heater control is US and needs replaceing . ( but I take it you have turned your heater to cold )
Dec 14, 2017 | 1997 Nissan Maxima
In the heat mode blows cold air heating element good condition
There are a few different things that could cause the heater to blow cold air. I would suggest looking into the different parts of the heater that cause the heat to be generated. If any of those are bad, it would definitely cause this problem. If you aren't able to find the damaged part, you should talk to a professional to look at it for you. Hopefully you can get this figured out without too much trouble.
http://www.getzschman.com/bellevue-ne-air-conditioner-furnace-repair-installation/
Jan 29, 2011 | GE Zoneline AZ38H12DAD Split System Air...
Compressor keep running in off position
you could have a relay or contactor inside the unit welded closed, therefore compressor will keep operating when unit is off. replace compressor contactor.
Feb 09, 2009 | GE Zoneline AZ55H07D Air Conditioner
Cold Air Penetrating from around & thru GE Zoneline 2100 Unit
There is a baffle/damper that allows outside fresh air to flow through the unit. This is only supposed to be open in cooling mode when the outside temp is moderate, or whenever you want just fresh air and fan operation.
Find the lever that controlls the baffle.
Some units have a switch in the control panel for this.
Jan 19, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Filters needed for Old GE Zoneline 2100
My name is brian pfeiffer . I run a ptac business in griffin ga. I have many parts and filters for most all types of ptac units. Please feel free to contact me at brian@dreamgreenservices.com. Nobody can beat my prices!!!! Or call me at 770-233-9987
Sep 03, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
2,990 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
