Duplex not working on sharp ar-m207
When pushing the option for duplexing it does nothing. It normally will ask if you want 1 of 1, 1 of 2, or 2 of 2. Any suggestions
  • Deb45 Jan 23, 2008
    Thanks for trying but this didn't help I suspect something is wrong in the control panel.
  • 61 Answers
Hi, i suspect duplex has been switched of in 'key operator programs', consult the manual to change this, or follow these instructions: press special functions, scroll down to 'key op prg', ok, enter 0000 (default number may of been changed), select copier, ok, scroll down to duplex, change to enable. Hope that helps
Andy
Posted on Jan 23, 2008
Is this the correct place to post questions for Sharp AR-M207 ARM207 Printer/Copier/Scanner/Fax?
Sir, normally you can not get firmware for any copier/printer unless you have access to the companies Secure servers, which house the firmware, Companies like Konica Minola, Sharp want to protect their software, must be a dealer or Corp Technician, Drivers are a totally different story they are normally free at the company web site, and are the best place to go for the most up to date drivers Windows 8.1 10 64 bit etc.
Jan 02, 2016 | Sharp AR-M207 All-In-One Laser Printer
My sharp AR-M207 is showing error H4.00 call for service i need solution
Enter simulation mode by pushing # * C * then type 14 and the copy button. The machine will restart and the error code will be gone.
Sep 26, 2011 | Sharp AR-M207 All-In-One Laser Printer
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
capacity.
2. Duplex setting is set for a single surface
model.
Apr 08, 2011 | Sharp AR-M205 Copier
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Jan 20, 2011 | Sharp AR-M237 Digital Copier
Sharp 5516 n legal duplex copying is not coming
Duplex unite only use a4 size not other size.You can try other size before configure.
Dec 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Where can i get a duplexer for the Sharp AR650?
Try eBay or Craigslist for a bargain, or contact your local Sharp Dealer in the yellow pages.
Sep 23, 2009 | Sharp Digital Imager AR-650 Black and...
Duplex Set-up fro Sharp AR-M455N
does the machine have a duplex fitted? as it is an option for this machine either called a du3 or du4. It bolts onto the left hand side of the copier. On the lcd touchpanel you should see it sais 2 sided next to the output box, tap it and select 1 to 2 or 2 to 2 depending on your origonals.
Dec 05, 2008 | Sharp AR-M455N Copier
Duplex printer
Check the driver you have installed on your computer, that's where the duplexing would be generated from. You should be able to choose through print properties at this point. Here's the link to Sharp:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Sep 10, 2008 | Sharp AR-507 Copier
69 people viewed this question
k24674
jasbo
jasbo
