Question about HP OfficeJet 6110 All-In-One InkJet Printer
Officejet 6110 all in one - printing problem with Mac Os X 10.5
Printer won't print a doc unless I set it to print only the 'current page'. Help!
Baught new Imac intel with sys 10.5. Copied all the old files across to new computer but now officejet 6110 will not scan. Only the scanjet slide scanner is recognized. I do not scan a whole lot of slides and the scanner won"t handle multiple pages. Help.
Posted on May 31, 2008
  • 406 Answers
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Posted on Feb 12, 2008
Hp printer won't print mac word doc
I wonder whether the Word Doc SDK I am testing these days can help with the related programs?
How to Get Started with VB NET Word
May 01, 2012 | HP Officejet 6500 AllInOne InkJet Printer
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Hi i am currently using Mac OS 10.6.7 i have already install Samsung SCX 4521F driver .. However when i use NeoOffice to print .doc document ,It printed out a blank page
make sur you have the right driver for your MAC OS ( the latest one is OS X 10.5 Leopard) as far as I know there is not a version for your OS X 6.7!
Apr 19, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have a Mac running OS 10.5.4 and an HP Officejet 5610 All-in-One printer. Is there a way to set a default so that it prints only in black (not color).
Hello, You can print a page in black in your Mac OS by following the steps given below. 1. From the File menu, choose Print. The Print dialog box appears, and the Copies & Pages panel opens. 2.. Change the color settings to black in the pop-up menu. 3. Click Print to begin printing. Good luck, ~regards, Jegan
May 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Printed copy in correct page order- HP officejet 6110
Hi :)
This may work and its only a few simple clicks :) but it will take less time then re ordering you pages :)
IN the printer settings or Print preferrences there should be a tab for "Advanced settingings"
Go to Control Panel and select "Printers"
Select the general tab and at the bottom of the window select "PRINTING PREFERENCES"
another window will open
from here select the Advanced tab
Find Layout Options in the list
click it you should see "Page Order" and a drop down menu for front to back or back to front.
switch it to whatever order it is that you need and test it out.
or if that doenst work try this:
Set the most frequently used copy settings as the default. This includes changes to Copy Setup options in the menu system, as well as other front panel copy settings.
  1. Make any desired changes to the copy setup from the menu or the front panel copy option.
  2. Press Menu .
  3. Press 1 , then press 4 . The settings are now saved.
these are the only ways I have found to correct the problem.
May 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer keeps showing a stop job with exclamation point
Do you have a Mac OS X?
Maybe you just need to reinstall the driver. Download it through the following link:
Let me know if it does not work and tell me what OS version you are using. Click on the Apple menu and select About This Mac to get the version.
Apr 15, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Hp 6110 printing double
Try copying. check its there or not.
If not, try unchecking all the options in the print options and try. then check zoom to fit. then try
Mar 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP officejet 6110 all in one
hmmm...odd to say the least..try this first..
print a test page from the printer settings page.
that should have text and graphics
Feb 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Bottom Margin Cut Off! :(
Your printer prints Letter format. Set the printer to A4 standard printing. As I remeber this tab is in the printer in the country/region section. Select your language and as a country select the Cech Rep. Is one of the countryes that uses A4 standard
Nov 15, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
168 people viewed this question
Ben Johnson
