Question about Sony CDX-F5510 CD Player
Cdx-f5510 my unit will not eject a cd, the same cd has been playing for weeks now, any way to eject manually? i press the eject button and it does everything else but eject
  • Anonymous Feb 09, 2008
    cd does not eject
Ok well listen to the radfio make sure its on tuner and wait for like thirty seconds then try to eject it while listening to the radio cuz mine is almost the same see if that works
Posted on Apr 28, 2008
6ya staff
SOURCE:
The player will not eject the CD, removed power and tried again many times how can I get the CD out?
Change the mother board of inner EJECT button with some other board.It worked for me when i replaced the board.
Jun 27, 2011 | Sony CDX-F5510 CD Player
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
My Sony CDX-F5510 won't eject the CD. I have reset it but it still won't eject.
try disconnecting power to the radio for a few hours. if that doesn't work, it probably has to be repaired professionally.
Dec 06, 2010 | Sony CDX-F5510 CD Player
Unit will not eject CD will play fine but won't eject
Once it gets too hot in your car, a stereo or the cd in it can warp.If you press the eject button and the music keeps playing the unit has an electrical problem you can't fix. If you press eject and the disc sounds, or looks like it wants to come out, you might have a warped disc. As a last resort, pull out the stereo and leave it connected. Then try to eject it. If it ejects, then the stereo could be binding.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
Apr 12, 2010 | Clarion XMD3
2002 maxima cd player would not eject
This is not a fix, but if you can see the CD and it's not ejecting, get two box cutter razor blades place one blade above the CD and the other under it. Squeeze the blades gently together using needle nose pliers. Be sure not to push the blades in too deep. Sometimes CD players will not play home copied CDs
Sep 14, 2009 | 2002 Nissan Maxima
My uv8 wont eject my disk
I suggest you disassemble the radio and take it out that way. While your in you can check on the blockage. Shouldn' t be hard. Good luck.
Jun 07, 2009 | Jensen Car Audio & Video
Can't get a CD to eject on my '05 RAM 1500 RBK Radio
We have tried several of the solutions offered. (i.e. holding eject button down several seconds and then pressing again; inserting another CD into slot 1.5 " and using eject button at same time; pulling the fuse on the radio and waiting 10 minutes w/o using key in ignition and then reinstalling fuse. NONE of these worked. There's a certain amount of satisfaction to "fixing" a problem on one's own, BUT nothing we read about and tried worked. Since we bought the 2005 RAM just last week, we're going to take the problem back to the Dealer to fix. THANKS.
Mar 23, 2009 | 2005 Dodge Ram 1500
Sony CDX-F5510 CD Player Logo
302 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
