Question about Garmin StreetPilot C330 GPS Receiver
Gps garmin the gps wass not correctly connected and it died. i made the right connection in the car to charge it, but now it will not even turn on. How do i get it running again.
  • 174 Answers
Null
Posted on Jan 28, 2008
  • audiqv8 Jan 28, 2008
    If this is a C330 then take the unit inside the house and try connecting the USB cable to charge it. Or if you have the AC charger try using it to charge the battery.
    Are you using the cigarette lighter adapter or are you try to hard wire the unit to the car? BTW the garmin cigarette charge will step down the voltage from 12vdc to 5vdc.
My Garmin will not start up.
it sounds like your battery within the GPS Unit is died. You need to charge it somehow. Keep it connected to the car charger for around 30 mins and unit should turn on. Do not keep it on while it is being charged
Oct 18, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Forerunner 305 keeps beeping, turning on and off every 5 seconds
I think I had the same problem. You do not write if your device were connected to the PC. My device was, and I finally got the suspicision, that it died because the battery was so low, that it crashed when the PC polled it as an usb unit.
So, I connected the unit directly to the charger unit that came with the unit, and now it works. So, try to connect directly to your charger, when your battery is totally drained.
Sep 16, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Nuvi 650 powers off when connected with car
I had this problem. The problem turned out to be my car charger. Hooking the GPS up to my computer allowed it to charge and operate normally. A new car adapter might fix you right up.
Jul 06, 2009 | Garmin nuvi 650 GPS Receiver
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin died and will not turn on
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
It took a nap...
Feb 18, 2009 | Garmin StreetPilot C330 GPS Receiver
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Losing Satellite signal
Latest software is 5.20, GPS sw 3.0
Go to the following link for more info on WAAS
http://www8.garmin.com/aboutGPS/waas.html
WAAS doesn't have anything to do with satellite reception.
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
20 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
