Question about Canon PIXMA MP530 All-In-One InkJet Printer
Change ink cartidges
I never change ink cartridges before. I need to change cause my ink is low. I don't know how to get to them to change it. I know its probably something really easy but don't know how. Please help.
  • janet616 May 23, 2008
    don't know how to change the ink on this type of printer please help me ASAP...I am out of INK and Need to print documents.
    President:
  • 4,402 Answers
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you change ink cartidges - 03rq02454_04.gif />
  1. Unpack the ink tank and pull the orange tape off completely in the direction change ink cartidges - 05sj00141_05_en.jpgmove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tapchange ink cartidges - 05sj00141_06.jpging problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protectchange ink cartidges - 05sj00141_07.jpgon the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Posted on Jan 22, 2008
I have a 645z printer and can't change cartrige it' alexmark
Posted on Mar 28, 2008
I have a Lexmark x3650, I just changed the ink cartridge and still get a message that cartidge is low on ink. How did I fix this?
Maybe the cartridge is not seated well in the carrier or just needs cleaning. Remove the cartridge from the printer. Follow these steps in manually cleaning the nozzles of the cartridge.
If problem persists, it's probably a defective cartridge. You might want to contact Lexmark Technical Support for assistance since it's a brand new cartridge.
May 03, 2010 | Lexmark X3650 Printer
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Apr 27, 2010 | HP Color LaserJet 2600n Printer
I changed the black ink cartridge and it is still saying the ink is low and im not able to print
check the cartridge with some other machine. You should do this by installing the cartridge on same model. There are chances of manufacturing defects in cartidges.
Apr 07, 2010 | Epson Stylus NX115 All-In-One InkJet...
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Nov 19, 2009 | HP LaserJet 1500L Printer
Problems with Lexmark X2550. I have refiled for the first time a lexmark 28 cartidge. Now I have paper jam all the time, I cannot print and I don`t know what to do. I blame the cartidge, because before...
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 03, 2009 | Lexmark X2550 All-In-One Printer
Still getting message empty cartidge lexmark x2650
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Printer won't recognize new ink cartidge
Most common problems like this come from non-genuine cartridges, or refilled ones.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Refilled cartidges
i believe u need to do printing alignment after putting a refilled cartridge, so it would detect that there is a new cartridge installed.
see link for changing cartridge
http://www.lexmark.com/publications/pdfs/3400/eng/ug.pdf
Mar 27, 2008 | Lexmark X3470 All-In-One InkJet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
2,120 people viewed this question
old marine
old marine
