Question about JVC TM-2703SU 27" TV
Nothing but static
My toddler did something to my tv I can only get two channels now and can't figure out how to get back to the channel my dish network is coming through on
  • 64 Answers
Dish is probably using one of the A/V inputs and not a channel. trying the video input or A/V button on your TV remote or on the front of the TV.
Posted on Jan 22, 2008
Channel not available dish
Heather,
I would be happy to help! I would just need some more information to ensure an accurate resolution. When you access the menu, does it say 'Main Menu' with options like 'Program Guide', 'System Setup', 'Preferences', etc...? What cable is plugged into the secondary TV? It could be a Coaxial (single black cable), or an RCA (Red, Yellow, White) cable.
Tommy Faust
DISH Social Media Representative
Dec 13, 2012 | DISH Network Televison & Video
What channel does the tv have to be on - I have dish network - do I leave the dish off or on and move it to a certain channel?
First check what channel or input your TV is currently on bypowering the TV off then back on and noting the channel or input that appearson screen when the TV is powered on. If you are using a Coax Cable toconnect the receiver to TV1, check the receiver's back panel for the outputname. If your receiver has a "TV CH 3/4 out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, if it has"Home Distribution" output (ViP Receiver): Tune TV to channel 62or 75. If using non-Coax (RCA, Component, or HDMI) to connectreceiver to TV1, cycle through the inputs until picture appears. In your casesince you have the Toshiba XDE500 connected between the receiver and TV, tuneTV and component to channel 3/4 (coax) or correct input. Hope this helps, andhank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Support Representative
Feb 08, 2011 | Toshiba XDE500 Player
I have Dish network. I want to record TV onto the VCR, but cannot get channels to record. i can playback videotapes and the record works, but cannot figure out how to get the signal to record.
The output of the Dish Network box should be hooked to the input of the VCR.
The output of the VCR should be hooked to the input of the TV.
The VCR should be on channel 3 to record. Select channel to be recorded on the Dish Network box.
It sounds like you have Dish Network box output hooked to TV input.
& VCR output hooked to an aux. input on the TV.
Nov 28, 2010 | Quasar VHQ401 VHS VCR
I have dishnetwork tv1 reciever is fine and shows tv2 is working but cannot see nothing but a blue screen on tv2. Dishnetwork will come out for 95.00 but the last 2 times they were here(free of charge),...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on.Wealso need to know what channel your TV2 is currently on, we will do this byturning the TV off then back on and noting the channel or input that appears onscreen when the TV is powered on, if the TV is not on channel 60 or 73, tune to60 or 73. Then Access "Modulator Setup"from TV1 by pressing"Menu", 6 for "System Setup", 1 for"Installation", then 5 for "Modulator Setup". Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture and the mode for TV2 is "Cable", change it to"Air" and change the channel on your TV2 to 60, if it is already on"Air" then change it to "Cable" then change TV2 to channel73. If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. The next thing we want to check is the connectionon the back of your receiver labeled "Home Distribution", this cablecarries the picture all the way to your TV2. Start by removing the connectionand screwing it back in, make sure all the connections going to your TV2 arehand tight. These steps should get your TV2 up and running.
We want to thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 02, 2010 | JVC AV-27530 27" TV
I got dish net work installed yesterday and it worked fine but when i turned the tv on the next day it was nothing but static and i cant figure out how to fix it so whats wrong and how can i fix it?
Guest,
The static you are getting on your TV is because the TV is not on the correct channel or input setting. With the 311 receiver, there is either a coax or an RCA cable (yellow, white, red) going from the receiver to the TV. If you have a coax cable, the TV should be on channel 3 or 4 (usually channel 3). With the RCA cable, the TV should be on an input setting. You'll need to go through your input settings until you find the picture. Of course your DISH receiver needs to be powered on. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 311 2-Room System DTV...
TV Stuck on 1 channel
We would be happy to help get that fixed right away. The first thing we want to ensure is that all connected equipment is on. We want to then check what type of cable was used to connect the TV to the receiver. If you are using a Coax Cable to connect the receiver to TV1, check the receiver's back panel for the output name. If your receiver has a "TV CH 3/4 out": Tune TV to channel 3 or channel 4, back if it is labeled "Home Distribution": Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1, cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or "Source" button. If we are still not getting a picture then unplug receiver for 10 seconds then plug it back in, this will reset the receiver, then try cycling the inputs again.
We hope these steps resolve the issue. We want to thank you for being a valued DISH Network customer!
Phillip Chang
Jan 22, 2010 | Emerson EWF2004 20" TV
Need an Input to hook up Dish network/xbox 360
Sometimes its tricky with those buttons on the front but with most tv's you can get to the menu and change inputs.
One you figure that out you will want to go back in and add that input as a channel in the add/remove channel section then you will be able to get to that input by just changing the channel down below 2
( another way to do this would be to run the auto program with the devices on and see if it adds them that way)
Sep 18, 2009 | Emerson EWF2004 20" TV
I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Mar 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Nov 14, 2008 | Televison & Video
Sony tv problem
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Sep 18, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
JVC TM-2703SU 27" TV Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
