Question about Trendware 54Mbps 802.11g Wireless AP
My airport extreme
Everytime i open my macbook my signal was on and off i have connected from airport express base station my network was on and off. i dont know whats wrong. can u tell what happen,
Just try, thanks
Posted on Jan 26, 2008
  • 40 Answers
Its Because If There Is other computers or another interference it blocks and enables and disables the conduct given off for your wireless router I sugest try repositioning a little sometimes also if you are to close to the access point it will also have slight delays and issues! or you may try deleteing and reinstalling the instalation cd I hope this helps!
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to open the airport option in your laptop and can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
Cannot get a PC to connect to my Airport Extreme BS
I had trouble connecting my PC to an airport network that my mac was working just fine on. I found this forum to get an "equivalent network password" and it worked great. The pictures were helpful too. Go to the Airport Utility and Then the "Base Station" header on your mac. Then select "Equivalent Network Password". It will be super long and lots of letters and numbers. Worked for me! Here is the forum:
Good luck, hope this helps!
Jun 17, 2009 | Apple AirPort Extreme Router
I am trying to connect to Broadvoice VOIP phone service using an SMC WSP-100 wifi phone handset. Trouble is, it won't recognize my wireless network, which is from an Airport Extreme base station. The...
I would assume that your neighbor is running a b or g network without password.
To eliminate the signal issue, do the trouble shooting have the phone at least 6-7 feet away from the Airport. Try to have the phone connected without the network password first to check if it detects it. You can either reposition the airport or change the channels to resolve this.
Check with the airport if it is running on N or 802.11n, have it set to b or g or if it is running on all of them, then it should be fine since the phone does not support wireless N. If the issue is with the security, try first to connect without any network password. Once you have the phone connected, try out the different encryption one at a time. The phone supports WEP, WPA and WPA 2. Encryption may be tricky as this stage as different manufacturers may prefer specific encryptions.
Jun 07, 2009 | SMC TigerVoIP SMCWSP-100 IP Phone
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Need to find the network key
Open up your airport utility software.
Connect to the base station.
Under the main menus look for network equivalent password.
Nov 28, 2008 | Apple AirPort Extreme Base Station
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Trendware 54Mbps 802.11g Wireless AP Logo
349 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
