Question about Sony VPL VW10HT Multimedia Projector
VW10HT screen filled with horizontal lines until unit warms up (5-10 minutes!)
My 7-year-old Sony VW10-HT front projector is exhibiting a new behaviour that leads me to believe it's wearing out. Until it warms up completely (sometimes up to 10 minutes) the screen is filled with heavy horizontal lines. Once it clears, the picture is fine. I replaced the bulb, but it didn't help. Any ideas?
  • babyrocket Mar 19, 2008
    bump
  • paulshep Dec 06, 2008
    same problem only worse takes over an hour now to clear then its fine filters all clean machine de-dusted new lamp no effect, obviously a component is tired anyone know which one
    Help please
I have a similar problem with our projector. It help to reverse the output for some reason. When reversed, all horizontal banding disappears.
Posted on Mar 08, 2009
I have a VPL VW10HT with a large horizontal line running through, the ipicture seems wrapped ???????
maybe
the Lcd panels are defective
or ,the Lcd panel driver chipset is not works
Jerry China Lampdeng Limited
Feb 19, 2014 | Sony VPL VW10HT Multimedia Projector
My screen has a blue cast over everything. On a clear screen you see blue lines running up and down the viewing picture
I have the same problem with blue vertical lines all over the picture... did you find a solution?
Nov 16, 2013 | Sony VPL VW10HT Multimedia Projector
I have a ps3 coonencted via HDMI to a Yamaha rx-v667. When viewing in a Sony TV, connected via HDMI to the amplifier, everything OK. When I want to have the output to a VW10HT projector connected via RGB,...
It could be your cable is too long and the attenuation is too much.
Can you use the same lead that you did for the TV ?
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sony VPL VW10HT Multimedia Projector
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
Aug 19, 2009 | Sony VPL VW10HT Multimedia Projector
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
When first turns on, large black horizontal lines make picture unwatchable.
from possltd@hotmail.com the problem is the 3 thin ribbon wires that go to the lcd have become lose,or something else open top cover 6 screws 4 on the sides 2 on top must remove dark gray plastic piece have pic if needed Oct 4th 09
May 30, 2009 | Sony VPL VW10HT Multimedia Projector
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony VPL VW10HT Multimedia Projector Logo
807 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
