Question about Crosley Songwriter (CR248) Shelf System
Crosley songwriter cd recording problem
My husband recorded a cassette to cd on the crosley songwriter - he finalized the cd but the cd wont play on any other cd player but the crosley - what went wrong?
  • Celeterhune Aug 12, 2008
    I have recorded records to cd and when I push finalize i get a message FORBID and the cd will only play on the songwriter not any other divice.
The cd drawer will not open, I can hear it trying to engage and open but it won't.
Posted on Dec 31, 2008
    Genius:
  • 1,067 Answers
Maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
How do I get the cassette draw to open on my Crosley Songwriter CD Recorder CR248?
Inside the unit probably is a small rubber belt which will operate the draw, it has possibly fell off or snapped. It will just need to be replaced. Look on e-bay for a replacement belt. You can get loads of different sizes cheap from China.
Jan 04, 2018 | Crosley Audio Players & Recorders
How do i repair the cassette player on my crosley CR248 songwriter CD recorder?
Generally when tapes spill out, its due to: A a belt that is off or loose. And B: a pinch roller that is off or worn.
Sep 15, 2014 | Audio Players & Recorders
CD will not finalize
No-way should it take that length of time to finalise anything. My DVD recorder only takes about 3 minutes at the most to do a 4 hour disc! CD are only 80 minutes max. I suspect you have an electrical fault on the unit. I would take it to the nearest Crosley Repair place.
Mar 27, 2014 | Crosley CR248 Turntable
TDK DA-5700 records from cassette to cd-R but nothing happens when I press FINALIZE and then PLAY (ENTER). Why?
Finalize is for multiple recordings. If its a single recording, its finalized by itself.
Feb 09, 2012 | Audio Players & Recorders
Why does my crosley turntable/cassette player/cd recorder cuts off when I play it?Whenever I try to record from a cassette to a cd it cuts off.
I would suspect that you have a bad record laser in the CD recorder assembly, this is common, and this is usually what it is. To this end you would need to replace this unit's laser assembly, it will/may still play a CD OK, but will not write to the CD, as they are two separate lasers. So if you wish to try to repair you will need to contact Crosley and ask them what to do, ask for a referral to an authorised service center or perhaps even return it to them? In any event ONLY ask for a "Quote" first and see how much it may cost before proceeding.
Oct 15, 2011 | Crosley CR248 Turntable
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
Crosley Songwriter (CR248) Shelf System Logo
649 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
