Question about GE Zoneline AZ55H07D Air Conditioner
Problem with AZ21E15EACV1
Unit # 1 was stuck on heat no matter what position selection switch was set. Replaced selector switch (WP26X35) & power pack (WP29X41). Nothing will run. This unit is 265 volt.
Unit #2 is stuck on heat also, just like #1. This is also a 265 volt unit
I have gotten no where with GE or the company tha I purchased the replacement parts from.
  • 104 Answers
If you know how to check these, try to check these, compressor, compressor capacitor and thermostat, hope this would do. tnx.
Posted on Jan 24, 2008
Heat/AC blend door position selector
Stuck doors or broken connection
Jul 21, 2013 | 1999 Chrysler Cirrus
Blend door postion selector
According to the book, I'm showing a mode actuator and a blend door actuator next to it. Some models use cables and some use small electric motors to move the doors.
Are you sure you are working on the right door ?
Not heating up right
Hi,when Element does not heat up correctly
1. Test for power to determine that the unit is receiving the correct voltages.
2. If the power voltages are correct and you have standard surface burner elements:
1. Test Surface Burner.
2. Test the Receptacle.
3. Test the Burner Switch.
3. If the power voltages are correct and you have solid-disc elements:
1. Test the solid-disc element.
2. Test the Burner Switch.
4. If the power voltages are correct and you have radiant heating elements:
1. Test the radiant heating element.
1. Make sure the controls are set properly that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
2. Make sure the oven door is slightly ajar as per your owner's manual.
3. If nothing else on the Range, Oven or Cooktop is working then:
1. Check the circuit breaker or fuse
2. Test for power
4. Test the broiler element.
5. Check the oven thermostat.
6. Check selector switch.
7. Check oven cycling relay.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION .
Please if no experience, please contact a skillful personnel for assistance.
Thanks for using fixya..and please don't forget to rate me 100%.
Thanks.
Oct 28, 2010 | Ovens
Hi - I'm looking for an Instruction Manual for an Integrated Oven HJA3650. This can be branded Lamona / Diplomat / Beko (and is made for B&Q / Argos etc). Can you help please
hello,
Operators Manual
Circulating Bath withDigital Controller
110-118
rev. A
Table of Contents
Section 1. General Information
1.1 Unpacking
1.2 Package Contents
1.3 Description of Circulating Bath
1.4 Specification
1.5 Circulating Bath Fluid Connections To External Apparatus
Section 2. Operation
2.1 Location
2.2 Filling the Reservoir
2.3 Reservoir Fluids
2.4 Circulator Pump
2.5 Closed Loop Circulation
2.6 Power
2.7 Setting Temperature
2.8 Setting the High Limit
2.9 Setting the Safety Thermostat
2.10 Operation of Refrigerated Models
2.11 Operation of Heat-Only Models
2.12 Selection of Celsius or Fahrenheit Readout
2.13 Optimization of Controller
2.14 Controller Display Messages
Section 3. Maintenance
3.1 Heater
3.2 Pump Motor
3.3 Condenser and Air Vents (Refrigerated Models)
3.4 Cleaning
3.5 Maintaining Clear Bath Water
Section 4. Troubleshooting
4.1 Unit Disabled - Service Required
4.2 No Pumping
4.3 Insufficient Pumping
4.4 No Cooling or Insufficient Cooling
4.5 No Heating
4.6 Insufficient Heating
4.7 Triac Failure
4.8 Controller Default Settings
Section 5. Service and Technical Support
Section 6. After-sale Support
Section7. Warranty
1.2 Unpacking
Your circulator is shipped in a special carton. Retain the carton and all packing materials until the unit
is completely assembled and working properly. Set up and run the unit immediately to confirm proper
operation. Beyond one week, your unit may be warranty repaired, but not replaced. If the unit is
damaged or does not operate properly, contact the transportation company, file a damage claim and
contact the company where your unit was purchased.
Remove any loose packing material which may have fallen into the reservoir during shipping. Also
check that nothing remains around the heater or circulator pump. Before proceeding, be sure the
Power switch is in the OFF position. Refrigerated models should have the Cooling switch in the OFF
position.
All TC-101D TC-201D TC-501D
Circulator Bath
Operators Manual 110-119
3/16in., 1/4in., and 3/8in. Nylon Barbed Tubing Adapters 510-011
6 ft. of 1/4in. ID Latex Tubing 300-299
Beaker Platform(s) for Bath Reservoir — 600 ml 701-402 701-402 (qty 2) 701-402
— 1000ml 701-403
Deck Lid(s) — solid 510-209 510-209
— w/beaker holes 510-211 510-209 510-211
Blue Hole Plugs — 31/2 inch 300-295 300-295(qty 2) 300-295
Note: Do NOT Use Above 120°C — 41/4 inch 300-296
Note: Work area "opening" is designed to measure samples directly in the bath. If additional viscometer height
i
Aug 28, 2010 | Ovens
I NEED TO KNOW HOW TO RESET YAMAHA 5990
Page 88 in the Manual:
Under ADVANCED SETUP
1. Press Master On/Off to set the unit to the standby mode.
2. Press and hold STRAIGHT / EFECT on the front panel; and then press Master On/Off inward to the ON position to turn on the power to this unit.
3. Rotate the PROGRAM selector on the front panel to select the parameter you want to adjust.
The name of the selected parameter appears in the front panel display.
4. Rotate the PROGRAM selector on the front panel repeatedly to change the setting.
5. s Master On/Off on the front panel to release it toward the Off position to save the new settigns and set the unit to standby mode.
THIS is the parameter you want to find in the procedure above:
"PRESET"
Use to reset all the parameters of this unit to the initial factory settings with the exception of System Memory and AUTO SETUP settings.
Choices: CANCEL, RESET
* Select CANCEL if you do not want to reset the parameters of this unit.
* Select RESET to reset the parameters of this unit.
Mar 30, 2010 | Yamaha HTR-5990 Receiver
1997 Ford Ka. Heat is directed to feet no matter
cable corroded up ,thats all so its getting stiff like my joints with old age
Dec 27, 2009 | 2000 Ford Focus
My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
When i turn on high beams sometimes my lights just go off. I then just keep flicking switch until lights come back on, 2003 impala. I also am having a problem with my selector switch that controls my...
the turn signal/multifunction switch is defective, the other problem is a vacuum loss at the AC mode control switch or the vacuum switch itself (part of the AC control in dash), check the vacuum resovior under the hood gfor leaks and make sure the vacuum reaches the switch in the dash.
Jul 28, 2009 | 2003 Chevrolet Impala
One day my RV Coleman ac just quit running on low cool but every other setting works fine. Any ideas?
Is your Air Conditioner run with a wall mounted thermostat or the ceiling pack controls? If it is the ceiling pack controls, then your selector switch has gone bad and needs to be replaced. This is located in the ceiling pack itself and is relatively easy to do. You can easily test it with an Ohmmeter, going through these steps:
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
* If you do not wish to remove the wires from each terminal,
disconnect the 9 pin plug from the a/c unit.
Hope this helps,
Jeff
Jun 27, 2009 | Coleman Mach 15 Air Conditioner
Blower motor vent selection switch not working
the hvac selector switch in the dash may be the problem.You need to remove the switch and look at the connector on the back of switch,see if there are any burnt wires at the connector or switch.It's all electronic and the switches have been known to burn out on this and other model.
May 26, 2009 | 1998 Buick LeSabre
GE Zoneline AZ55H07D Air Conditioner Logo
126 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
