HI. Generally, this will be the result of a communication error. There is, possibly, a bad connection at the control panel board. This connection may be worn,or simply disconnected, slightly. Gain access to the back side of the control board, and check to make sure of proper connections at the control board. If you notice a slight separation of any connector, simply reconnect it, tightly. If there are not separated connections at the control board, replace the control board, entirely.
Thank you for your post, friend!
I understand that your Electrolux range is displaying an "E14" which is currently being displayed on your Electrolux range. Which means the display tail is missing or not connected. It could be a loose connector within the control panel. If not it could mean a replacement of the main control board or keypad.
I would recommend performing a reset on your appliance which you can do by disconnecting the power from your range. The best way to do that is by unplugging it or flipping the household circuit breaker for ten minutes. Hopefully this is helpful. -Matt
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
