Ze5400 laptop problem
It doesn't boot up. I ended up re-imaging it. It then worked fine for about 2 hours. After that it just went to sleep. Pushed the on/off button and it still doesn't work. After some time, I got it to start to boot, but froze. I even went into bios and it froze while I was looking at the tabs. Any help would be great.
  • pryeager Jan 22, 2008
    I had the harddrive running on my desktop for a few hours and was having no problem with it. Could a bad laptop battery be the cause?
    Sergeant:
    Champion:
  • 306 Answers
Try replacing the "cmos"battery, have the hard drive tested for failing...you could even go to bestbuy and geeksquad will run diagnostics on it and tell you whats wrong for $59. then you can deside what you want to do from there.
Posted on Jan 22, 2008
6ya staff
SOURCE:
Laptop screen goes off and then to sleep mode
go into your control panel and under power saving turn off the sleep mode settings also check power saving sleep mode settings in bios by pressing f2 at boot also check battery options in security settings hope this helps and yes hp techs are just high paid plumbers reading memos from screens so there not usually much help lol
Mar 01, 2013 | HP Pavilion Computers & Internet
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
I recovered from a system image, and Onekey Recovery doesn't work anymore
System image has to have exact partition and format to clone. Two adjacent partitions can not do cloning. Fat table addresses needs to be offsetted and NTFS file system would be incorrect. You need two exactly identical hdds to be cloned(no replacement track and sectors), switch drive to boot. At the end of each day they have to be cloned again for the next day. Think backup would be safer with writebacks.
Feb 11, 2012 | Lenovo Computers & Internet
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
Acer aspire one, won't wake up from sleep mode, screen blank
I'm having the same problem, but I don't want to have to turn off my computer EVERY time it does this. (I have not been able to shut down the laptop normally because it goes into sleep every time.) I've heard that after 3 hours it builds up an eletrical charge and you have to take the battery out, but I havn't had it on for 3 hours at a time.
Oct 25, 2009 | Acer Aspire 5610-4648 Notebook
Ma acer aspire 5738z does not atart at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
sounds like sleep mode created a conflict while downloading updates.and your pc is still in sleep mode..about the only thing you can try,is reinstalling everything..may work may not
Oct 16, 2009 | Acer Aspire 5735 Notebook
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Open Questions:
Computers & Internet Logo
97 people viewed this question
Ekse
Marvin
Marvin
