Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Mod ATF7000es
Washer won't start.
  • 2 more comments
  • dsdsedfs Feb 27, 2008
    Same thing here. "lock" lights up for a few seconds after start but shuts off
  • Nylexie Mar 22, 2008
    GLTF2940ES machine will not start. I am receiving ERR LOC. I've tried unplugging to reset but to no avail.
  • classicryan4 Sep 16, 2008
    The controls are locked. How do you unlock them?
  • robert samples May 11, 2010
    try opening and shutting the door firmly is the door lock light on also make sure the dispenser drawer is shut then advise are the control lights on
  • 156 Answers
If its the electronic control model the control panel board bad
Posted on Mar 06, 2008
We have a frigidaire model atf7000es, it just started when the cycle starts it goes to perm press no matter what starts at 48 goes to 32 stops than goes to 38 starts back to 32 and repeats its self
Hello Ken, thank you for your post!
I understand that your Frigidaire washer is going directly into the perm press cycle no matter which option is selected. I would suggest performing a reset on the washer and you can do that by disconnecting the power from it for at least ten minutes. If the reset does not correct your issue, you may need to have the control panel or a wiring harness replaced. If you need help disassembling your washer I would recommend seeking a professional technician. You can locate a technician by contacting your manufacturer. Hopefully this information is helpful to you. -Matt
Apr 26, 2016 | Frigidaire Washing Machines
Machine starts beeping when not in use
Good Afternoon Eylene,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, beeping while it is not in use. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your washer, if it is still beeping while not in use, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
Apr 18, 2014 | Frigidaire Affinity ATF7000ES Front Load...
How to engage diagnostic mode for affinity ATF700es
Open the lid by removing the 2 screws in the back and you will see the tech sheet on top of the dispenser housing
Feb 17, 2013 | Frigidaire Affinity ATF7000ES Front Load...
My dishwasher is liking water.I am under the warranty. What should I do?
Sorry but your post is a bit confusing. You have 'Problem with the Frigidaire Affinity ATF7000ES Front Load Washer' as the title but then go on to say 'My dishwasher is liking water'!
Anyway whichever it is, and I presume it is your washing machine, you say it is still under guarantee so clearly you should invoke that guarantee anyway. No-one else should touch it.
Firm advice ;-0)
John C
Feb 16, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Washer won't start and DR displays
means door is open. If door is infact closed, i would say you have a faulty door switch. Replace and test, part number is 131763202
Apr 07, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Frigidaire ATF6000ES Front Load Washer Logo
135 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
