Question about Dell 922 All-In-One InkJet Printer
Problem with 922 AIO printer: Gives alignment errors and prints test page with Ghosts
Hi: My dads 922 started printing what looks like duplicates (ghosts) for each line of text . Appears to be an alignment problem so I ran the alignment procedure and still have the same problem. I found out there was a printer cartridge Jam that occurred during cartridge replacement, after the jam the printer ran fine for a week now gives the ghosting problem. I ran the default setting procedure in case somebody had tweaked the margin settings. Is there a sensor that verify's/adjusts the alignment and how do you adjust it or check adjustment?? Any other solutions you can offer? Thanks,Jim
  • 3 more comments
  • Anonymous Oct 03, 2008
    Mine also pirnts a column and then skps a column of text - it looks like stripes going down the printer
  • Anonymous Oct 28, 2008
    the interlaced lines or offset, but it is at random some lines print fine or mostly fine with a missing line of pixels at the top of the type.
  • mnebz Nov 13, 2008
    My problem is about the same...some lines print ok, but most are either doubled or there are large gaps, splitting lines over about an inch of paper or so. Not sure how to even go about fixing it...I've run about every troubleshoot there is on the Dell Panel.
  • weistao Nov 20, 2008
    I have the same problem with the 924 model.
  • Anonymous Dec 14, 2008
    Printer is ghost printing
SOURCE: Not printing extreme right side of page
It is either your drum or open front cover see blue handle @ right hand side pull it out look at rignt hand side of printer and a door has opened (only small) pull the blue lever out and move the pad back andforwards a few times this cleans the glass.
It worked for me but I have to do it fairly often but it samve buying a new drum etc
Posted on Feb 26, 2008
yooperbud
  • 8637 Answers
SOURCE: Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
Ajkill
  • 2035 Answers
SOURCE: error problems wi Dell 626 all in one printer
Try these steps if this did not resolve try to clear the memory of the printer
and try to print ..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Feb 03, 2009
bgdstepdaddy
SOURCE: dell AIO 942 printing problem
Thhe problem is that the paper is not feeding properly, sometimes not at all. The feeder rollers are turning but nothing is happening. Also, the print is sometimes out of register printing the line slightly misaligned twice
Posted on Mar 07, 2009
Thiru77
  • 33 Answers
SOURCE: Dell AIO 922 printer not seeing the color cardridge
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" Click here and slecet the operating system and download the drive
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Posted on Jun 17, 2009
Dell printer 922 will not print with vista just gives error message ''test page failed to print. operation could not be completed (error ox000000006)
Some older printers are not compatable with Vista, I have VMware virtual machine running so that xp drivers can be used to print with printers that don't have Vista drivers.
Oct 13, 2009 | Office Equipment & Supplies
My Dell 922 AIO prints but cannot scan. There is
Make sure that your printer is set as default printer in the Control Panel.
Sep 14, 2009 | Dell 922 All-In-One InkJet Printer
I have just change printer cartridge, the display is now showing printer error 1203 followed by cartridge missing could you assist me with this issue please
Hi!
To resolve the printer error 1203 on your Lexmark X5470 All-In-One (AIO) Inkjet Printer, you need to perform the following tasks---
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. if the error message return then continue to print a test page. If the test page prints, the error is resolved. If still the power persists then you need to open the top cover of the AIO and remove both cartridges from the AIO. After that power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on and if the error message return then there is a hardware problem with the printer. If error message not return then you need to again power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover. If the error message returns then you need to clean the cartridge contacts.
Again try to rest it by powering off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover. Now print a tests page. If the test page prints, the error is resolved.
Cleaning the Cartridge Contacts
1 Open the top cover of the AIO and remove the cartridges.
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts.
Checking the Cartridge
To see if the cartridge is defective, replace it with either a new cartridge or a known good cartridge from another printer of this type.
1. Turn the printer/All-In-One off and unplug the power cable from the outlet.
2. Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3. Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
4. Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5. Repeat Step 4 for the other cartridge slot (if applicable).
6. Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7. Plug the printer/All-In-One back into the power outlet and turn it back on.
You should only follow the steps below to resolve a print quality problem if you have already attempted to solve the problem by printing a "Clean Print Nozzles" page.
Cleaning procedure - Remove the print cartridges. Moisten a clean, lint-free cloth with water. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the downward direction while keeping the print head in downward position on the cloth. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the upward direction of the print head.
With another clean section of the cloth, repeat steps 2 through 4 above. Allow the nozzles and contacts to dry completely. Reinsert the print cartridges. Print the document again. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
If still the error message persists then you need to contact the Lexmark.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Jun 17, 2009 | Dell 922 All-In-One InkJet Printer
Print head problem
Do a reset:
Dell Printer reset
1. With the power on,unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket.
Dell Printers
To run a nozzle clean, perform the following steps:
1. Verify the All-In-One Printer 922 is powered on and connected to a computer.
2. Verify that the paper support (input tray) has clean, plain white paper loaded.
3. Press the Menu button.
4. Press the Down button until Mode: Maintenance appears on the LCD screen.
5. Press the Menu button.
The Dell 922 Maintenance Menu appears on the LCD screen.
6. Press the Down button until Clean Cartridges appears on the LCD screen.
7. Press the Start button.
The AIO 922 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 02, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 AIO does everything except print from PC
Two things to try:
1. If it prints the alignment page, sometimes you have to put the page back on the scanner glass and hit continue or start on the printer for it to scan back in the alignment page to complete the alignment process
2. If thtat's not it, try going to add/remove programs in control panel and uninstall all dell pritner software, then reinstall using the link below:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=rc1057382&l=en&s=biz&ServiceTag=&SystemID=PRN_ALL_A922&os=WW1&osl=en&catid=&impid=
Mar 28, 2009 | Dell 922 All-In-One InkJet Printer
My dell aio printer 922 will not print
my dell aio printer well not print systen 32 spool driver is close how do i get it to come on
Feb 06, 2009 | Dell 922 All-In-One InkJet Printer
Hi,i'm using dell photo aio printer 922,i keep getting the blank page when i give print...even the test page is not printing.please help
check the ink levels. if they are not low, try to clear NVRAM by pressing the Scan button and the Up button at the same time to enter diagnostic mode. Use the Up button or the Down button to go to the option for Clear NVRAM on the LCD and press Menu to confirm. Press Menu again when asked if you are sure. Press Menu again when asked if you are really sure.
Feb 01, 2009 | Office Equipment & Supplies
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
Replaced colour cartridge and got error 1203
Power off the All-In-One (AIO) and remove the power supply fromthe back of the unit. Wait 30 seconds, then reinsert thepower supply and power the AIO on.
Did the error message return?
Yes:Continue to Step 2.
No: Print a test page. If the test page prints, the error is resolved.2 Open the top cover of the AIO and remove bothcartridges from the AIO. 3
Power off the AIO and remove the power supply from the back of theunit. Wait 30 seconds, then reinsert the power supply andpower the AIO on.
Yes:There is a hardware problem with the printer. Continue to ContactingLexmark below.
No: Continue to Step 4.4
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the color cartridge. Close thetop cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 4. If you have already tried cleaning the contacts,continue to Checking the Cartridge.
No:Continue to Step 5.5
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 5. If you have already tried cleaning the contacts,skip to Checking the Cartridge.
No:Print a test page. If the test page prints, the error isresolved.
Nov 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
190 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
