Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 42 this televivion set powers up with proper sound. However, the picture seems to roll. There are lots of horizontal scanning lines on the sceen but everything is blurry(the colour look like they are not properly mixed). i was adviced that the two big STK ICs could be faulty or the hyper module needs servicing. where do i go from here?
  • shurman francis
    shurman francis Jan 23, 2008
    ill get that done and let you know whats up
    thanks
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 22, 2008
FIXS LNES IN TOSHBIA SRS WOW THEATER WIDE TV !
sounds like vertical retrace lines. The horizontal line fault called so. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Apr 23, 2016 | Toshiba 32A33 32" TV
Toshiba tv, turns on with sound but no picture.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 22, 2015 | Toshiba 36A40 36" TV
Sound but no picture toshiba 35a44
Oct 18, 2014 | Toshiba 35A44 35" TV
I have an old 42" phillips 120 hz 1080 I flatscreen ...it's about 4 years old.when you initially start it,you get both picture &sound then picture disappears &sound remains.15 minutes later turn it off...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
Jul 16, 2014 | Televison & Video
Toshiba no picture
Jul 10, 2014 | Televison & Video
Why my toshiba 40H80 has no picture only sound
Jun 29, 2014 | Televison & Video
My toshiba 42h83 tv has sound but no picture
of course check different inputs etc to make sure something did not get disconnected.
This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.
No simple answer as a lot of different parts are possible for this problem.
Apr 27, 2012 | Toshiba 42H83 42" Rear Projection...
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Picture on 42HDX82 vertically stretchs after about 10 mins
Sounds like a bad cap, spray some freeze around till you can duplicate the problem.
Oct 22, 2007 | Toshiba 42HDX82 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
